Reliable tuning S3 8l
pyle
Sofia
Hey guys,
Ross here newbie in the s3/turbo/4x4 world and after much reading and mostly friends who love these cars have given me guidelines on what and where but they mostly put together very fast/complicated projects together and drive them to the car meet and so on. I'm looking into building an S3 but retaining reliability by reaching the safe limits of the stock k04 and engine internals by optimising intake, exhaust, cams and so on. I wanted to know what is the state of tune where the car still remains reliable for day to day driving and retains some of the fuel economy ( I'm aware it's not a fuel efficient car) at least not loosing it. My personal concept if I build an engine will be a high CR big turbo low boost setup but it's not going to happen with the S3.
Of course all modifications will be done after the vehicle is in good mechanical condition. Is there any other reliability upgrades to be done prior to tuning apart from a new oil pump and ancillaries? Appologies for the spelling mistakes. I've been reading for a while now forgive me if there is another thread like this one..
Welcome for safe and reliable (if such thing exists with an s3) stock internals and turbo you will be looking at a stage 2 setup theirs no need to change cams if you’re keep stock turbo
Things you will want
Intake pipe badger5
3” exhaust
FMIC
Exhaust manifold (avoid eBay or relentless ones as the just crack you’d want a ported chinafold) also if I were you I’d get a compression test done befor you start chasing power so you know you have a healthy engine to start with
Hah I guess by reliability I mean not breaking due to too high boost or too large of a turbo, and by cams I mean a N/A inlet cam, not sure why VAG install a larger cam on the exhaust side when they (in/ex) flow exactly the same and small turbo high boost engine benefit from a larger inlet cam. I got the idea from the old C20LET engine where they gain 30hp from N/A XE inlet cam. Not sure it works here though. Thanks for the mod list that's what I was going for and I also am thinking of adding the red coil pack, seem to benefit a lot on fuel and driveability. As I'm a drag racing guy would you say this mod list is enough to get me into the 13.XX 1/4 mile? Would you recommend any reliability tips I mean apart from maintenance know weak points like the oil pump?
PS. I saw you mentioned the 3" exhaust, from the calculators I've used 2.5" (63mm) is good for 250-60hp is it necessary to upgrade do 3"?
The red coil packs are just for looks and don’t improve anything if I remember rightsly. Swapping the cam for ma does give gains but don’t think it’s much on the standard ko4 (10-20bhp maybe) Fuel pump could be getting tired by now so I’d change that if not been done if your looking squeezing power out of it. I like my fast cars(if you can call the s3 one) but Don’t know about 1/4 mile times but on stock turbo you will be looking at around 280bhp on a healthy engine and these are heavy cars remember
To be honest I doubt the 280hp as that requires a perfect map which unfortunately we are lacking here in Bulgaria.. I'm hoping for high 260hp. Fuel pump sounds about right, is it better to get a 255lh one of just an original brand new one? What would you recommend about the FMIC pipe diameter? I know the diameter for the inlet side of the engine should always be wider than the exhaust or at least on a N/A engine.
It's forced induction, there's not really a benefit to back pressure required on n/a
Having experience around z20let and z20leh engines I know what you’re on about regarding the c20 cam swaps that people do. But swapping cams out on the 1.8t 20v is not necessary at anywhere near the power levels you’re mentioning. You’re looking well above 400 bhp before the cams are holding things back.
Welcome to the site. Like JonnyDerv mentioned, not worth wasting your money on cams. I’m only doing this modification because I’m going to be running a very high spec hybrid turbo, so small gains are possibly available. But generally cams on these cars will only show good gains with a big turbo setup.
As for reliability, go about replacing all the known things that go wrong with these cars, hoses, bushes, small things like that. For cheapish power gains don’t go for anything more than stage 2 (approx 270bhp) to get this, you’ll be looking at 3” downpipe, catback system, front mount Intercooler, Jetex air filter, possibly a new fuel pump (DW65) keep the car regularly serviced.
Thanks guys a lot for the comments. I've been reading about intercooler size people mention around 3l per 100hp, and injectors as per calculators will be maxed out around 260-70hp do I go for 440 or not needed?
I am just a beginner at this, but I think the better the flow the better the spool as the gas needs , also the heat dissipation improves as K04 hotsides crack, along with the manifolds, even if they are not visibly cracked on the turbo to manifold hotside the internal parts do too. you will struggle to get much bigger than a 3inch downpipe fitted even the stock I think is 2.75 but it splits into two pipes to go to two cats then back to 2.75. some experts on here have fabricated a 3.5 inch but not on a stock K04.
Upload 2019 1 31 18 8 15
if you are only going for 260-270 the stock injectors should manage that - but if upgrading avoid those 440 green giants they dont suit these 20valve engines, I just fitted Bosch 550 injectors and adapters with my hybrid, but I am miles away from making any real power yet. just slowly building up my knowledge.
So the larger the better, doesn't that hurt spool?
for your levels or power expectation and turbo use you can retain the small port head as is, std cams and std bore if not looking to do a rebuild/refresh but would suggest rods and exhaust valves plus a head refurb as these are the main bits that fail on old 1.8t engines... if doing rods you should inspect the bores (do a compression test and leak down test prior to stripping) and fit fresh rings doing a deglaze light hone to the bores to bed them in... run the engine in on mineral oil to get the rings bedded in (normal run in procedures still apply here)
3" dp and a decent straight through exhaust (pref 3") would be suitable but 2.5/2.75 will do as long as there are no chambered silencers involved
Use no bigger than 63mm charge pipe work from the turbo if changing it all but tbh the std 60mm will do for your power level
Use a toyosport type B (wellycooler) FMIC if you want some decent cooling although again something like the Airtech should so just as well and be easier to fit...
Spool on a K04 won't be worse... if anything it will be better with the above... and of course fit a badger5 TIP if you can (I am assuming you are LHD so the B5 or any of the copy 80mm TIPs are a tight fit due to the brake servo location)
Thanks again I am LHD so the Badger5 wontw fit I guess, I have a buddy who can build me an aluminium jntake to suit and wrap it with a 80mm maf housing and air filter to suit.
Use the stock maf housing... Do not make one... You will regret it massively as it will be very difficult to tune...
Std S3 maf housing has been used on 400+hp builds but sensor does top out at 292gs on wideband ecu's which is around 360hp worth of air... You just tune them a little differently
Okay which intake will suit my build if I can't fit the Badger are there other 80mm intakes?
It's being 80mm that's the problem due to lack of space... Bills v3 tip "fits" once trimmed but still sits on the brake master cylinder
There is a thread discussing this so prob best to have a read and decide for yourself
What is the problem if its made custom? Why will it be hard to tune,?
Custom TIP is fine but using a 'custom' MAF is not so much as they are a ball ache to recalibrate by people that know what they are doing let alone someone that is less familiar with it... if you are going to struggle to find someone to clone your ECU then chances are you won't find someone that knows how to recalibrate a MAF sensor
Make a larger TIP then just use the std S3 MAF... there are absolutely no wins for doing anything else at your level of tune and if you were in a position to run more power than the MAF could theoretically deal with I would suggest using a standalone like the Ignitron ECU I use and go MAF less as upping the MAF sizes to deal with higher HP figures cause more issues than they solve... especially as your ECU is a narrowband one which makes them even more tricky to dial fuelling in correctly
Ohh okay understood now. Is it beneficial to fit 80°C thermostat to keep engine a bit cooler over summer? Is it necessary to change the original DV (and the n249) for a better one or just change it for a brand new one?
Don’t bother with the thermostat. Your DV, unless you know when/if it’s been changed, is probably tired so replacing that is a good idea. An OEM one is fine or a forge 008p if you want something abit more bling. I’d ditch the N249, there’s tons of videos online how to delete it
Reactions: Phil wilson
Lol yes keep it plugged in but ditch all the other junk and just run a simple pipe.
Reactions: hendo#1 and <tuffty/>
Can I just plug sth to keep the signal flowing like a transistor or sth like that?
In the N249?.... people have used resisters with varying success but I just extended the wiring to hide the valve out the way
In the 249 plug yes to simulate whatever value is required. Whats the problem with just renewing it and keeping it functional. Not sure what the 249 actually does. I thought the 112 is the odd one out.
N249 allows the ECU to open the dump valve if it detects a situation where it needs to drop boost to protect the engine... you don't need to remove it but most people do for aesthetics or to get rid of pipe work that could split...
The ECU will still be able to cut boost with out it as it will cut N75 duty and shut the throttle plate so its no real drama...
N112 is for secondary air... only relevant on an APY narrow band S3... later AMK/BAM S3's don't have this
So if I change the pipe lines I can keep the 249 valve I dont care for underbonnet aestethetics, there is a plastic cover for that hahh.
Yeah... Sure :)
The plastic cover hides all sorts of stuff ;)
20180902-96dpi-img_20180902_194907-jpg.164448
Reactions: hydro s3
The n249 also apparently holds some boost between gears 1 and 2 and internet rumours suggest it helps the engine run more efficiently when there's no boost in constant vacuum eg 1-2k rpm, as it stops the dv from being opened by the vacuum.
But as most 1.8t owners are more interested in performance than +1 mpg they just junk it as it removes 30% of the potential leaks.
Yeah... Sure :)
Cant hide that manifold though hahh I don't care for few mpgs but I prefer to keep the car as standard as possible and only if hurts performance or engine running but I guess I will try both and see what I prefer.
I've been reading for the bypass having peaks and spikes in boost of throttle and normal town driving.
N249 delete just makes a complex system, simple.
Implications being, less problems, less leaks.
Actual functionality remains the same, regardless of what people report
I mean there was a reply to the first post from someone sort of questioning the information but I don't know better...
I forgot one thing though how does the factory clutch kit hold my desired power figures and standing starts?
