Audi S3 "Punisher" 2.1L stroker build, image heavy
Have you seen any measurements recorded of how the x-parts manifold flows......total flow, equal distribution of the ports?
Nope. only that its identical to one that had 1000hp flow and equal distribution and when I measured this, it seems to be 100% match, excetp I have to polish insides.
Reactions: ADs3
Sounds interesting. I did check there site out but couldn't find any data on it & looked online also for any info on how it performs against other similar manifolds but couldn't find anything either. Looks like a nice piece of kit but would like to see some hard evidence on it before I pull the trigger.
I have seen picture of flow and Number were
  • Runner 1 - 290.424839 CFM
  • Runner 2 - 289.215817 CFM
  • Runner 3 - 288.897168 CFM
  • Runner 4 - 289.169699 CFM
average per cylinder.
https://store.034motorsport.com/034...take-manifold-transverse-1-8t-large-port.html
Its 100% copy of that.
Here where I live is now two 2litre stroker both producing over 850hp and same intake. 2nd Audi put out 853hp on oem throttle body! Think about that :D
Reactions: ADs3
if X-Parts one is copy of 034 which is based on Grams Honda one, we ran a test on it vs IE vs SEM... On a 550bhp car the IE was 15bhp more and SEM was 25bhp more than the 034 one. All on 80mm Throttle body
fyi
Reactions: Warsuperior, S3AMJ and ADs3
fyi
Cant beat back to back testing like that, thanks Bill
hmm ok my comment didnt post here but thanks badger5! I was aware of that too, that there is differences. Friend has the 034 one and he had problems too but he modified it and now has over 850hp on that intake.
Do the arp head bolts not take more strain over the oem one's? If so with you putting more torque threw the engine would the arp ones not be best.
Friend who has the drag racer had some problems with knocking etc. he tightened the ARP bolts to 110Nm and almost all problems disappeared.
Of course Im not going to do this since I dont have over 200hp/cyl :)
Some more stuff appeared btw.
2L surge tank for dual AEM pumps
Tial wastegate 44mm by trix
Polishing inside of intake.
Before:
Soon there:
61084214 10211329549673309 1595949640342044672 n
61175724 10211329549113295 1098310823639515136 n
Fluidampr arrived:
61263876 10211329549393302 6576279401934094336 n
Reactions: Rainbird
Engine, crank and head are on machine shop.
Deck+head are smimmed, crank inspected and dual pinned crank gear incoming. They machine valves too since I cannot be ***** :D
Too lot to do anyways :)
I really cannot wait to see how lot torque this thing can push on lower rpm. Driving in city should be easier too. Im just now settling in with 6speed box, Im so used to drive in 2nd with 5speed and now 3rd is the way to go.
IDK should I remove the gear shortener, I have now twice put it in 3rd instead of 5 and on high rpm damn! Well not so high that over 7k but near it..
Any tips on elevated shifter or something?
I was thinking of keeping car OEM look but I ordered plastic fender flares and I kinda liked the look. I like bit "race" look and in end its my car so dont really care how others look it(mostly they see it from behind :p) but open for opinions as usual :)
Still pondering do I put in SMF and Sachs SRE stuff or keep the LUK DMF with Sachs 4paddle and sachs pressure plate(not sre). Tuffty has pushed this to 440lbft without problem but launching I dont really think is wise with this... Alltho I can always break it, then renew :D
So update topic.
Ive had lots of problems with build. Head had to be skimmed again, since the was scratch between 2&3 cylinder.
Pistons had to be cut down to get oil squirters to fit
One piston ring cracked(own fault) had to get new one.
Crankshaft trigger wheel had to be welded(actually melted with TIG) to make sure it wont move
Oil pan needed to be grinded to fit ARP main bearing studs
I chose Sach SRE SMF kit to be clutch of choise
I coated pistons with slick ceracoate on sides, heat dissipating below and top
Silver-Project rear trail arms
69241050 10211839167933447 1766563355000045568 n
Titanium vs oem retainers
67494902 10211689860080844 2051249098937335808 n
Installing valves with 15€ lawnmover tool
67403106 10211680460405858 2839971971142254592 n
Coated parts
67879054 10211728544367927 7761892436661501952 n
ACL race bearings
67814919 10211728543647909 3294329607834042368 n
Millers drive-in oil 10w-40
67688758 10211722674901194 1256214407218724864 n
Balancing report after tig weld plus flywheel plus clutch plate plus camgear
69896233 10211824700091760 5212528363767332864 n
Dual AEM 400lph
70303453 10211899707166890 4853546896859332608 n
ND to EV6 adapters and 11mm->14mm injector adapters
70063853 10211899712727029 730589828428595200 n 70242771 10211899714767080 2798817671821393920 n
Waiting for head to be installed
71063865 10211953966803347 2837989362698813440 o
Athena 83,8mm and 1,4mm thich race MLS head gasket. CR is now about 9,24:1 or bit more
71477246 10212025399949131 2096432253675503616 n
Head painted
67595262 10211680467326031 8497245976526848000 n
67367381 10211680470326106 6805716533411577856 n
Block painted with acid black
67824352 10211680463845944 5275838526762516480 n
Valves all in with dual sprins+titanium retainers. Guides changed to exhaust side and Inconel supertech exhaust valves
67247419 10211675205434487 9217120484322181120 n
Filing piston rings
67585189 10211722452895644 807400662773006336 n
Making adaptor from old cambelt gear to fit the timing wheel
71497124 10212038161748168 2317954104023842816 n 72165452 10212038162348183 2399946889425321984 n
Engine and head assembled together and starting to set Cat cams 3658 timing
72949064 10212038236510037 3540490916760387584 o
Reactions: baliszoft
Reason why the trigger wheel is melted is because using old one, the bolts go too deep. Picture here to explain
I decided to run E85 with engine since I am soon in city where E85 is available. We shall see what kind of figures we can push out :)
Most likely, I will drop some hp in favor for reliability and as daily driver, I dont need full power nonstop but more torque on low to mid is best :)
Going to take S3 apart this week or weekend.
Car is now running and under tuning! Lots have happened and I didnt post here lot but I have a facebook link where is tons of pics, info etc.
Bill from badger5 helped me A LOT and I cant ever thank him enough for not losing nerves with my endless questions!
Alltho my understanding of english did make things worse and I had to ask until I understood but never the less, Bill was amazing help. Also Balasz from Ignitron and so many others.
Along the way I ran out of time and had to make some changes. Last specs are
AGU head refurbished
OEM intake valves and OEM old guides just machined old valves to seats
Supertech Inconel 1-Groove exhaust valves machined to seats
Rosten-Performance double springs with titanium retainers
CatCams 3658 set with adjustable wheels
Rosten-Performance adjustable cam wheel
Athena 1.4mm and 83,8mm MLS gasket. CR is now 9.2:1
VVT with Ignitron control
AGU base engine bored to 83mm
83mm 9.5:1 CR Je-Pistons with better flame travel profile
FCP 144mm X-Rods (should handle more torque than H)
ACL Race/King race bearings, OEM pressure bearings
ALH 1.9TDI 95.5mm stroke balanced and polished crank with 1.8t modified cam belt wheel+2 extra pins on crankshaft for cam belt wheel
Melded(yes melted with TIG so no balance change) trigger wheel to camshaft
GTX2860R genII with T25 cast manifold
Rennsport HRT intake(smallport) with spacer from small to big
OEM TB
3" Downpipe with 3" SS exhaust with 3 magnaflows
600x300x76mm FMIC
K&N RC-5112 air filter
Intank OEM pump new
AEM 400LPH in-line pump under car
Ignitron Ecu
1200cc EV14 Injectors
OEM fuel rail OEM style adjustable FPR
Sachs race engineering 7.2kg SMF and full clutch kit with 4-paddle disk
SSQV dumb valve
I also now have flexfuel sensor fitted ready, LCR fuel filter moved where active charcoal chamber was.
Also hilarious image when I got my wastegate control fcked and on 4000rpm it pushed 2.24bar like for second, I know it doesnt reflect real life but I gotta say, car was insanely fast on that drive, even I didnt rev it much. boost was almost instat cus the pressure pushed wastegate close :D
78614275 10212405713656736 4585008383119065088 o
here is FB link
Code:
https://www.facebook.com/groups/203244473354322/permalink/949480938730668/
Perhaps not prettiest S3 out there but next summer I polish and paint etc.
Car is now in "winter" mood also. Dont like the rear and the sideview rear is bit too low vs front.
Happy new year to you aswell mate.
You seem to be hammering on there rightly in the snow. I know your more used to it than what we would be but still going quickly.
Thank you Hydro s3 :)
Only good thing about winter is that you can powerslide everywhere :D With ignitron haldex control the car is quite nice when 50/50 power delivery.
On drives I have it on OEM mode but still it tries to push rear to side :)
I bought this yesterday 034 big port intake, heavily modified with 1litre spacer (approx 3.3litres volume now) polished and improved flow.
Been on 900hp drag racer stroker here.
I can use now my 80mm Hemi TB and finally get more out of big port head.
81021048 10157254590933167 504112397569490944 o
Also last year I got very very very cheap Golf R 2011 DSG box that has been only sen approx 90 000km
It leaks between seals but fixable. Only leaks when its running.
its DQ250 MTX box but it will be strong enough for my use. Can handle 600Nm and even heard that someone has with 650Nm daily driver this box.
If I would want it more strong, I could upgrade the packs inside of it but Im sure this will handle my power/torque anytime.
Now I only need rest parts for DSG swap :)
78686741 10212341692536248 8911753691170603008 n
Interesting year going to be this 2020
G25-660
Better intake
DSG!!!! controllered by Ignitron
Reactions: hydro s3
I started to rip the DSG apart and fix the leak issue.good but the 2nd lock ring I cannot get off so I had to order special pliers and I get them tomorrow. After I I can rip the DSG in 2 halves, check the leak and fix it and hopefully it can be fixed.
Also my roofliner was hanging so I took the lining off and added some Ground zero noise killer mat, also there comes another layer of soft mat to absorb sounds.
Only problem is that I dont know for sure how to fix the hanging liner. Any tips appreciated!
Can anyone remember seat LCR fuel filter code? I cannot and I would like to order new.
I have video of taking DSG apart but I have not edited them yet.
Car ran for few secs with DSG and horrible grinding noise. I think its the middle metal sheet between gearbox and engine and I really really hope it is not hard to fix and I have a clue where it came from, possibly the rear small cover is bend inwards and makes contact to flywheel.
Positive was that at least now it didnt leak so far, I hope it wont start when I get more pressure to it.
BTW the CR is 9.8:1 I had wrong figures on one spot whe I calculated it, so no wonder it started to knock with 98 fuel on 1.2bar boost, now its E85 and car worked really well with it.
Then I noticed the ECU wont talk to DSG and of course it wont if you forget to connect +12v acc wire D'oh!
I have run into problem after problem after problem and making things worse, my hands are overworked, they hurt day and night so I have had to push this project forward and forward.
New parts or changed:
1300cc EV14 matched set https://finjector.com/eng/ev14_1300_cc_12_ohm_c_jetronic_liitin_keskipitka_o_o_49_mm-p-486741-0 I really suggest this place, they ship worldwide too. Fast&Great customer service, fast shipping and delivery in total, make account if you order(the more you buy, they give you personal discount that applies to prices when you login) These have very great spray!
Turbosmart - GenV HyperGate 45 14psi External Wastegate
Now I am missing downpipe+wastegate pipe+some breather lines. So close but so far away still...
Not much I know but I am not good with making downpipes or the pipe for wastegate. Now the downpipe has to be put in below with twisting it many times to it goes to place. I have to weld 2"v-band close to the pipe for connection to wastegate and then I hope it still will fit.
All this on ground too witch is pain in *** to do.
119206409 419576312351505 5016686133424783718 n
List what you need:(at least on my build)
- DSG, I have MTX Gearbox from Golf R 2011 (its been said it can handle 650Nm on stock clutch pack so I kept it, I will limit torque)
- ECU what can control it, I prefer and suggest Ignitron, it is the best there is
- Electrical connector round for DSG box 1J0927320
- Electrical connector for DSG shifter 1k0972776, doesnt come with connectors so get them elsewhere, on VW they cost 15€/pcs and that price is a gunless robbery! Dont waste money on the VW fix wires which are 15€/pc here at least! You can use the small amp square connectors that cost less than euro, sorry I forgot the number for them. Get 5 of them but I usually buy more cus i **** them up regulary. I suggest buying good crimping pliers example aliexpress.
- Right side driveshaft flange from 02M gearbox, the one with MTX and seems with others too, dont fit
- Driveshafts: Left fits just like that, right you have to cut 40mm. I cut mine with lathe and TIG welded. I could not find ones that would fit without modding and I tested 9 different driveshafts. TT 3.2 ones dont fit with this one
- Flywheel 06F105266L or Sachs 2295 000 541
- Bigot bearing middle of flywheel Sachs 1863 869 047 <-DO NOT forget to put this in
- Starter motor 02E911023L
- 2 coolant hoses 8N0121096H coolant hose from DSG cooler to waterpump. 8N0121073A, coolant hose from interior heat exchanger to DSG cooler.
OR DIY hoses, i used 16mm 90degree ones 2 of them, warmed the hose so I could push it to one way valve
-One-way valve 1J0122351
- Engine mounts 1J0199117AT/ 8N0199555G or use OEM S3 mounts, the fit except on transmission site you are missing one bolt and there is chance two wont hold it in place BUT 1J0199555BB seems to have right bolt pattern and looks like it fits, I have not tested it.
- DSG shifter from Passat B6, touran dont fit to 4wd, see pic
106782443 10213758774722417 8353891115735235058 o
Optional:
- better clutch pack 02E398029C, I am going with OEM cus I dont plan pushing over 600Nm nonstop and ppl say that this OEM pack should hold 650Nm without slipping if you program it to clamp harder
- Oil filter housing made from aluminium with fins for better cooling. I bought mine from china and it was ******, idk did i get unlucky since others bought same and they got great item.
- CAN support cluster to see what gear is engaged, I skip this for now or make external that shows me it but I dont really need it for now.
- Paddle shift, basically on/off switch for Ignitron and digital inputs
My list for parts from where I got them from:
- Sachs flywheel 2295 000 541 (Autodoc)
- Sach bigot bearing 1863 869 047
- CASCO starter motor: CST10444AS (Autodoc)
- Elring DSG cooler O-rings 886.810 (Autodoc)
- Vaico repair kit with DSG oil pan, oil filter, O-rings for electrical round connector, 6litres of DSG oil V10-5138(Autodoc)
- Elring park gear axle gasket(renew if leaks) 886.780 (Autodoc)
- Elring metallic gasket for oil pump DSG 149.060(Autodoc)
- Shifter from Passat B6 junkyard
- Driveshafts left fits, right one you need to cut 40mm DIY
- One way water valve 1J0122351
- Cover for clutch pack and hydraulic block gasket maktrans poland, almost all gaskets are one time use on DSG as listed below
- 16mm and 19mm ID diameter water hoses with 90 degree corners on them, they are cheap and must. Even better to get few of the ones that have several curves, makes things easy.
Repair parts for DSG, these are bare minimum you need to open box and assemble:
- 02E321385A Gasket for oil pump, needs to be renewed (
- 02E301580C gasket for hydraulic block, needs to be renewed(cant get from VAG they don make it but eg. maktrans poland makes it)
- 02E301205C cover for clutchpack, has to be renewed -everytime
- 02E301859A Lock ring for clutchpack cover, has to be renewed
- the round electrical connector needs new o-rings everytime too.
- DSG cooler needs new 2x O-rings
For sealant to use, when mating casings back together, Elring AFD2018 was the one I went for. Anaerobic, I could not find anywhere what they use when they make DSG so I saw one elring video they used this.
So what else?
G25-660 is now in
Wastegate is turbosmart hypergate 45 instead of Tial
Battery is in trunk now, 50mm2 welding cables full copper, small strains version(better conductivity)
Start and stop battery 75Ah
300A automatic fuse
Also amps are in spare wheel cowl, pics are from not ready state
118970052 10214134383272396 1618532047617524692 o 117109541 10213949826338588 5961028685908413089 o
Wiring DSG connector
118926728 10214134396352723 3674228488679095008 o
DSG pinout, these are from my car but this is the pinout on 20pin ones almost all same, to my knowledge. Please check your gearbox one before doing this. I am not resposible for errors.
118922761 10214134404712932 4759702292155252433 o
DSG shifter pinout
118918948 10214134406192969 2290639322180913290 o
New subframe because old ones dogbone nuts got loose inside of the frame and I could not get them to stick or weld.
107117628 10213778633538875 3680894287854533347 o
Had to cut triangle out of body so the DSG would fit, the OEM intercoolers hook into that. I dont know why but gearbox would not fit without removing that. There seems to be different version of S3 where that thing dont exist (?) since few ppl said they dnt have it. I know A3 might not have that but they said they have S3. and no, I did not cut the frame, only the triangle what is made of thin metal. So frame integrity is still same
108109789 10213823510660775 5424586640753645431 o
Passat shifter in, I broke the button from this when I tried to remove it. It had crack and got loose. I have been trying to find new button but not luck yet.
118979596 10214134387032490 7402201149345785009 o
Lathe cut the right driveshaft
106913152 10213772157816986 6132192102636746685 o 107051071 10213772157536979 6542558167852958124 o
Tig welted shaft ready for paint
118936237 10214134381632355 5421119525199420609 o
Making new engine mounts, Shore65 rubber. Cheapest mount and 1litre kit approx 60pounds and they do not move :D
106079800 10213745866119710 3267960850704399921 o
Getting there but still to do and tidy stuff up. I put vacuum block top of intake. I know my engine room is nothing beautiful like others but I make it so it works. The line to air filter too is going to be different, that was just a test
118914367 10214134388352523 528500198548725006 o
Final waterlines for DSG . I put extra bolt on that tranmission mount, made threads to the one connected to transmission but I have the right mount too. I was thinking of testing this and to see is that 1 extra bolt enough, so you could use S3 oem mounts. If it moves I replace it.
From picture you can figure out how the water lines for DSG go too or at least I think you can make it out
115806207 10213904955776852 5858219404535280055 o
thats it so far. I cant list all the trouble I have had with this project and I think its last time I touch the car. No more changes :D
moro! en nyt millään löytänyt keinoa lähettää sulle yksityisviestiä, niin laitan nyt tänne.
Luin jossain ketjussa, että sulla saattais olla tuommoseen 1.8t AGUun valmis ohjelma. vieläkö löytyy?
