ACC Enable from CC/Pre-sense/Lane Assist spec A3
S15LVO
Hi all
I am looking for some advice and discussion as to see if its possible or if any coders out there are happy to investigate if it possible to (code) Adaptive CC in to my 56 plate A3 etron.
My car already has Cruise Control, Lane assist Camera (I know it doesn't need this) and the front facing radar used by Pre-sense.
I am not interested in adding the ACC stalk as I already have the standard CC stalk. I don't need the distance control switch as either it should use the middle setting (3) by default or it can be set with in MMI.
I found a post online where it mentioned some German techs had enabled it but who knows.
As I think I have all the kit in the car surly it just a codding / licence / software fix?
I retrofitted acc on my car .
I guess all is standing or falling with having acc fec code in your gateway. The fec code cannot easaly added to the car. (There are few options)
If no acc fec you need to upgrade the Acc sensor to
5Q0907541 these don't need fec. Only cp
After this: i think the stalk is necacery to activate acc.
Next you need to check the rear ABS sensors (if you have thr grey ones your good to go.)
All in acc upgrade is around 350euros.
Hello,
Only 350 Euro, May I ask where you did it?
BR,
