xkieron99x
Lately there been a lot of discussion of how to enable the rear speaker on half amplified cars, this "guide" will explain to use why you need one of theses harness and what type of harness you need and is pursuing you’ve got either a universal headunit (such as a pioneer or Sony etc) or a no name Chinese headunit who’s harness isn’t working properly
TAKE NOTE: this guide is a work in progress and is produced using information gathered around on this forum, contacting several audio shops and connect2 website, some information maybe incorrect. so if any errors are found please indicate them i'll will make sure to update this post.
Right some background first, all cars that have rear speakers have a sub in the boot which is powered with it's own amp. The amp needs a signal to turn on and produce sound, if you're really unfortunate and your car doesn't have rear speakers equipped then you're going to have to retrofit fit in and use an aftermarket amp and sub. - this guide will not apply for you
First identify which headunit you have as this will effect what harness you need. if you have the single din concert
or double din symphony with the cassette type
then you will need one of the following harnesses:
if you have this type of headunit and your new headunit has rca out this get this type of harness
http://www.connects2.co.uk/Product/ProductItem/CT20AU10
if your new headunit doesn't have rca out then get this harness
http://www.connects2.com/Product/ProductItem/CT20AU09
Now if your car has the newer double din concert, chorus or symphony headunit that looks like this
you are going to need a different harness due to the Audi changing the audio wiring harness when they swapped to this headunit
Again if your new radio has rca out then use this harness
http://www.connects2.com/Product/ProductItem/CT20AU08
at the time of making this guide i haven't found a harness that clams to enable the rear speakers without rca output, if anyone finds one please post it below
AGAIN TAKE NOTE: this guide is a work in progress and is produced using information gathered around on this forum and contacting several audio shops, some information maybe incorrect. so if any errors are found or there are newer updated harnesses, please indicate them i'll will make sure to update this post.
