Error code 01152/temp gauge S6
scotty7519
Scotland
I scanned my car for codes the other day an Audi S6 V10 5.2 and wondered if anyone has come across this error code. It’s to do with the coolant fan I think also I have noticed the temp gauge takes a while to go to 90 degrees and also noticed on the motorway the temp gauge can drop to 70 degrees then returns to 90 on normal roads.
Got it booked in to a local garage but just wondered if anyone has come across this?
16864/P0480/001152
Contents
16864/P0480/001152 - Coolant Fan Control Circuit 1: Electrical Malfunction
Possible Causes
  • Fuse(s) faulty
  • Coolant Fan Control Module (J293) faulty
  • Coolant Fan 2 (V177) restricted/jammed
  • Wiring and/or Connector(s) from/to Coolant Fan Control Module (J293) faulty
  • Wiring and/or Connector(s) from/to Coolant Fan 2 (V177) faulty
Possible Solutions
  • Check Fuse(s)
  • Check Coolant Fan Control Module (J293)
    • Perform Output Test
  • Check Coolant Fan 2 (V177) for Restriction/Blockade
    • Check for Foreign Objects and Accidental Damage as well as Restrictions
  • Check Wiring and/or Connector(s) from/to Coolant Fan Control Module (J293)
  • Check Wiring and/or Connector(s) from/to Coolant Fan 2 (V177)
Special Notes
  • Remove the Coolant Fan 2 (V177) Fuse(s) for Safety Reasons before checking it
  • When found in a 2011+ 3.0TDI (4H) Chassis A8 check the wiring near the engine controller for chaffing. The Black and Yellow trace wire damage in this example picture may be helpful
Reactions: scotty7519
