Mista J
Hi all, im new to to the site.
Im just wondering if anybody here has ever changed a steering rack on an 8v or has any information about it. My steering rack needs replacing due to it being cracked. I was told that i cant replace it with any steering rack that will fit because extensive coding will need to be done etc. It’s the programming part im trying to avoid. Trying to find plug and play if thats even possible so i have been trying to match the code with the code found on the motor part of the steering rack (not sure of this is the code i need to be matching but guessed it is probably this seen as this is the part that electriconially plugs into the car )
This second code i am guessing is the column part number.
Zoomed out view
So far i’m struggling to find the exact code. Mine is 3Q0909144E and i am finding mutiple with the last letter changed (e.g 3Q0909144F, 3Q0909144G ) im not sure the boundaries on using these other racks or if its even possible. I thought about buying a new steering column and fitting my old motor thats already programmed onto the new column. I have heard this might not work as it will put the motor timing off. So i am just hoping somebody can shed some kind of light on the situation if anybody has had any kind of experience with these in the past.
Zoomed out view
