I have aprrox 74,500 miles on my BUL, was always service by Audi when I bought the car.
I am concerned about the oil pickup pipe, I know there is a revised part now and im thinking of getting it fitted.
The question I have is, how do you know when the pickup screen blocks and the relief valve opens to stop the engine get staved of oil???
I have 72k on my BUL engine and it has the original suction pipe.
To be fair the problem is not really with the original suction pipe, agreed it is not the best of design and in the longitudinal configuration the sump does slope the wrong way...but its more to do with servicing and oil contamination.
A lot of owners have had engine failures put down to blockage of the guaze and the oil starvation , but when they have had the sump off its not just oil blocking the gauze , there is assorted debris stuck in it and onto it with very nasty black thick oil.
Long life oil changes and servicing really don't help and with short trips as the oil just goes bad and it's been pumped around for ages just getting worse.
TFSI's like and need good clean oil , not thick gloop, so regular oil and filter changes are a must to keep the gauze as clear as possible.
Just be aware that a web search on the problem will also show that many owners also changed to the alternative part and still had engine failures so kinda proves the point that the original part does work ok if the engine is maintained on a regular basis.
Also the PCV design on the tfsi is part to blame , if you saw the nasty gloop that get's put back into the sump you'd understand why the engine oil does not last long and how it can breakdown into a very unfriendly black product that just is not any use for anything frankly.
I my view yes the modified part is a good thing but not really convincened it really need's changing , there are a heck of a lot of a4 B7's with the tfsi engine in all driving around with no probs at all and with high milage , and yes there are failures , but one only ever hears about the bad things , rarely the good things.
I work on the basis of regular oil and filter changes, never do a long life schedule and use the best oil possible, also modify the PCV ….work fine for me.
All down to your personal choice though.
rob
