Audi Sound System - Centre Speaker Fault?
AndyB-S3
Dundee
Afternoon all,
Not been here for a wee while hope you are all well!!
Anyway I have 14 reg S3 and having a couple issues with the speakers.
I have the *** and for a while I was getting a crackle from what seemed to be the rear of the car. When I went into the boot I could hear that it was coming from the sub, I unplugged it and left it out for a while then plugged back in and seemed to be ok but then few months later did the same so i repeated the unplug etc.. for the now its ok but wonder if I need a new sub?
The next issue I am having is I jump in the car start up and start driving. 5 mins later the centre speaker (i think) starts hissing/crackling and this can last from 5mins to 20mins. It stops if i mute the sound but straight away comes back on when un-mute. Is it easy enough to replace this speaker or has anyone had similar issues and it wasn't actually the centre speaker? Might be the treble speakers front left & right? It does sound like the centre though.
Anyway any advice is appreciated, thanks for reading.
Andy
Think there was a few threads on here about the amp failing/MMI unit failing. Rare the speaker gets faulty, amp are generally not powerful enough to blow a speaker at least in my experience as Audi would safeguard this from loads of warranty claims cause punters have turned the volume up too much.
Things I would check, is the connector loose/broken? Does the cackle happen when engine isn’t running to rule out electrical noise from alternator? Check the cables.
I get the exact same crackling from my speaker in the dashboard at the centre. I have the Audi sound system too and the problem sounds very similar, I haven't done anything about it since sometimes its fine and i cant recreate the sound so i'd probably take it in and it would be fine knowing my luck.
Evening all,
Same here, not been on for a while, but having the same issue, with the passenger side door speaker in the door card. I thought it was the amp and changed this but the sound is still there. Any help would be appreciated. S3 2002
Evening all,
In the wrong section mate try the 8L forum page
