Q7 Audi Q7 - Reverse Camera & Sensors not displaying on MMI
Faizan
Hi guys,
I've got a 2006 Audi q7 which I'm struggling with. It's battery had died, and ever since I've had it started back up (running for a few days now) and the battery is showing at 100% battery charge.
The issues I am having are that my parking sensors more my reverse camera works anymore. The display no longer shows my camera / parking sensors.
I've done a scan and the following is what I see.....Any help is appreciated!!
Wednesday,17,October,2018,17:34:48:20893
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ4L97D057531 License Plate: DK56XTT
Mileage: 147550km-91683mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 13 15 16 17 18 19 34 36 37 3C 42
46 47 4F 52 55 56 61 62 65 67 6C 6D 6F 72 76 77
VIN: WAUZZZ4L97D057531 Mileage: 147550km-91683miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4L0 910 401 M HW: 4L0 907 401
Component: 3.0L V6TDI A001AG 0030
Revision: --H03--- Serial number:
Coding: 0011775
Shop #: WSC 31414 790 00001
VCID: 2C5CD39E8F5AAA2A59-8078
2 Faults Found:
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 38
Reset counter: 255
Mileage: 147137 km
Time Indication: 0
Date: 2018.10.04
Time: 23:26:49
Freeze Frame:
RPM: 945 /min
Torque: 62.4 Nm
Speed: 0.0 km/h
Voltage: 13.91 V
Duty Cycle: 80.9 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
001025 - EGR System
P0401 - 002 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 147230 km
Time Indication: 0
Date: 2018.10.06
Time: 01:13:54
Freeze Frame:
RPM: 1827 /min
Torque: 124.8 Nm
Speed: 93.0 km/h
Duty Cycle: 55.8 %
Duty Cycle: 20.9 %
(no units): 0.0
Duty Cycle: 11.0 %
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FK HW: 09D 927 750 FK
Component: AL 750 6A 0940
Revision: 00H52000 Serial number:
Coding: 0000504
VCID: 7CFC23DE3FBAFAAA89-8028
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H21001
Coding: 0562321
Shop #: WSC 00641 210 88433
VCID: 28542F8E9BA2860ABD-807C
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0240
Revision: 07020801 Serial number: 10601100546125
Coding: 0000151
Shop #: WSC 31414 210 01865
VCID: 63CE78A2A2042552A8-8036
Subsystem 1 - Part No: 4F0 910 131 G
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 K
Component: FBSAUDIC6 IDG H01 0060
1 Fault Found:
02764 - Access/Start Authorization Switch (E408)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory BFS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0078944
VCID: 61C272AAB8183742BA-8034
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 387J/067526482
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 3A70E5C6750E049ADB-806E
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000001140939
Subsystem 3 - Serial number: 0104.08.080000000100010916ÿ
Subsystem 4 - Serial number: 010916ÿ
4 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 17
Mileage: 146337 km
Time Indication: 0
Date: 2018.06.22
Time: 10:27:55
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 246
Reset counter: 109
Time Indication: 15
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 15
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 59
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:17:16
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---011 Serial number: 00000000078564
Coding: 0001046
1 Fault Found:
02380 - Positioning Motor for Right Side Vent (V300)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 163
Reset counter: 76
Mileage: 147134 km
Time Indication: 0
Date: 2018.10.04
Time: 22:51:44
Freeze Frame:
Voltage: 12.00 V
Temperature: 26.0°C
(no units): 51.0
(no units): 86.0
Temperature: 23.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0113121
VCID: 3064C7EEA372CECA65-8064
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H08 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 147548 km
Time Indication: 0
Date: 2018.10.11
Time: 16:47:00
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 147548 km
Time Indication: 0
Date: 2018.10.11
Time: 16:47:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 111 A HW: 4L0 035 111
Component: CD-Changer H41 0100
Revision: 00000000 Serial number: AUZ5ZBF3054241
VCID: 1E380956C9E648BAC7-804A
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 HW: 4L0 907 561
Component: ABSTANDSREGELUNGH05 0120
Revision: -------- Serial number: 00000000000000
Coding: 0031158
VCID: 66C861B65136507A4F-8032
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 114
Mileage: 147335 km
Time Indication: 0
Date: 2018.10.08
Time: 02:40:20
Freeze Frame:
Temperature: 13.0°C
Voltage: 9.09 V
Bin. Bits: 01000
Hex Value: 0x0346
Hex Value: 0x0003
Speed: 0.0 km/h
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 B HW: 4L0 959 655
Component: 30 AIRBAG AUDI8RH38 0120
Revision: 05H38000 Serial number: 0037GD06UPES
Coding: 0013104
Subsystem 1 - Serial number: 6332QSME1774391DK
Subsystem 2 - Serial number: 6342QSME18171E07F
Subsystem 3 - Serial number: 6352QSME151078111
Subsystem 4 - Serial number: 6362QSME1511144FA
Subsystem 5 - Serial number: 63734SME15094425V
Subsystem 6 - Serial number: 63834SME151B4821Z
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026062570116
Coding: 0112152
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 A
Component: KOMBIINSTR. M73 H17 0170
Revision: 00400000 Serial number: 5HD32L186
Coding: 2801443
Shop #: WSC 12345 067 57207
VCID: 234E38A2E2846552E8-8076
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 C
Component: Heizgeraet H07 0060
Revision: 0000000E Serial number: 00000009011043
Coding: 0000002
VCID: 60C477AEB3123E4AB5-8034
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06923813A
Coding: F5DFFF7F357202
Shop #: WSC 00641 210 91756
VCID: 6CDC139E4FDA6A2A19-8038
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 109
Mileage: 147134 km
Time Indication: 0
Date: 2018.10.04
Time: 22:53:52
00463 - Control Module for Digital Sound Package (J525)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 69
Mileage: 147393 km
Time Indication: 0
Date: 2018.10.09
Time: 03:17:52
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 F HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7750
Revision: --H03001 Serial number: 15.1528-0095.2
Coding: 0015510
Shop #: WSC 00272 210 89558
VCID: 2D5ADE9AB440A3224E-8078
2 Faults Found:
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 31
Reset counter: 168
Mileage: 147147 km
Time Indication: 0
Date: 2018.10.05
Time: 01:04:11
Freeze Frame:
Error Code: 68
03004 - Load Level Button (E539)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 2
Reset counter: 168
Mileage: 147388 km
Time Indication: 0
Date: 2018.10.09
Time: 01:58:18
Freeze Frame:
Error Code: 156
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H01 0100
Coding: 0074858
1 Fault Found:
01447 - Sensor for Driver Seat; Height Adjust (G231)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 76
Mileage: 147132 km
Time Indication: 0
Date: 2018.10.04
Time: 22:52:28
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H48 0850
Revision: 00000000 Serial number: 399JZ067540550
Shop #: WSC 00641 210 00243
VCID: 3B7EE0C27A343D92C0-806E
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 80
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:17:30
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 A HW: 4L0 907 566 A
Component: J0769_SWA_MasterH06 0060
Revision: 00H06000 Serial number: 6PZ 009 014-00
Coding: 0001101
Subsystem 1 - Part No: 4L0 910 568 A
Component: J0770_SWA_Slave_H05 0060
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F11.10.0600H0500000010198ÿ
Subsystem 4 - Serial number: 010198ÿ
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0019163
VCID: 2F66C492BE4CD1327C-807A
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 27
Reset counter: 71
Mileage: 147318 km
Time Indication: 0
Date: 2018.10.07
Time: 02:47:09
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01021352220000
Coding: 7610619
VCID: 3162C2EAA878C7C26A-8064
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000015459
Coding: 0011101
VCID: 5EB84956896608BA87-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0019163
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000022
VCID: 29522A8A80A8BF02A2-807C
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH06 0002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388J+067561717
Coding: 0000001
VCID: 2E58D996B946D83A77-807A
2 Faults Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 116
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:18:01
Freeze Frame:
Fault Priority: 7
Fault Frequency: 197
Reset counter: 116
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.14
Time: 17:17:22
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000049459
VCID: 64CC7BBEA70A226A51-8030
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2610121199
Coding: 344630393135313035442056413032363130313231313939
2 Faults Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 35
Reset counter: 255
Mileage: 146359 km
Time Indication: 0
Date: 2018.07.08
Time: 12:38:25
02256 - Quiescent Current
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 9
Reset counter: 82
Mileage: 147011 km
Time Indication: 0
Date: 2018.09.21
Time: 00:53:58
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0018442
Address 65: Tire Pressure Labels: 4F0-910-273-HI.lbl
Part No SW: 4F0 910 273 C HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900018242
Coding: 0222424
4 Faults Found:
01467 - Front Left Tire Pressure Sensor (G222)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 46.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01468 - Front Right Tire Pressure Sensor (G223)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 49.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01469 - Rear Left Tire Pressure Sensor (G224)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 52.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01470 - Rear Right Tire Pressure Sensor (G225)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 146343 km
Time Indication: 0
Date: 2018.06.22
Time: 11:06:40
Freeze Frame:
(no units): 46.0
Voltage: 14.10 V
(no units): 55.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000610050117
Shop #: WSC 12336 024 394758
VCID: 3668F1F64116E0FA3F-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6943EY
Coding: 1021001
VCID: 244C3BBEE78A626A91-8070
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD18.10.06--H21001001A0084ÿ
Subsystem 4 - Serial number: 1A0084ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002082422-----
Coding: 0003587
VCID: 264821B691B6907A8F-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0018442
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 42
Time Indication: 0
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330628502951
Coding: 0221146
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007639070
Coding: 0010920
End-------------------------(Elapsed Time: 03:31)--------------------------
This may or not apply in this case, but cars with CANBUS shut down none essential electrical services when the battery is failing. This could be one of the first to be shut down.
