I’m looking for some information on which 2.0T FSI crankshaft to buy for my build. I’m a little bit confused and keep getting conflicting information on which part number or engine code to go for. I want to get a forged 92.8mm stroke crank and I have always been under the impression that any 2.0T FSI 16v crankshaft was forged and then it just needs the 1.8T oil pump gear press fitting on but some people say they have differences depending on the engine code and some are not suitable for a 20v stroker build due to being cast and not forged???
I’ve seen a reconditioned one for sale with part number 6AAJ apparently from engine codes CDL BWA BGB AXX. I don’t know if it is forged or cast but I messaged the seller who told me it’s been crack tested and alignment checked. Journals have been polished with main journals being standard size and the big end journals are 0.25mm undersized
First question, Is this the correct part number I’m looking for from the engine numbers above? If not what should I be looking for?
would 0.25mm undersized be out of tolerance on the big end journal?
Or should I be looking at buying a brand new part from a main dealer?
Steve
Steve
just trying to find out what codes they put on the web of those cranks because no ones sells them under the AR part number.
