hi guys just wondering if you can help me on this issue, i have a 2008 audi a3 sportback 2.0 TDI DSG. Seller stated non starter ecu/electrical fault (he just wanted to get rid of it) as soon as I got it i fiddled with it kept resetting the fault codes and it magically started and drove absolutely fine. Next morning its doing the same thing, when i turn the key there is no crank.
So im just wondering whats the next steps, and what to check, i checked the starter motor it seemed ok and tested it and it works, before i send the ECU of for a test. Heres the vagcom scan
Friday,14,September,2018,12:08:36:48797
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WAUZZZ8P98A1-0--0 License Plate: A-08 T--
Mileage: 80160km-49809mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 77
VIN: WAUZZZ8P98A120580 Mileage: 80160km-49809miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
Component: R4 2.0l PPD1.2 G 1247
Revision: --H52--- Serial number: AUX7Z0GDFN409T
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 74E7A3CE1705B2E40C-8020
1 Fault Found:
005714 - Please check DTC Memory of Transmission Controller
P1652 - 008 -
Freeze Frame:
Fault Status: 01011000
Fault Priority: 0
Fault Frequency: 6
Reset counter: 40
Mileage: 80162 km
Time Indication: 0
Date: 2018.08.23
Time: 01:15:34
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 10.96 V
Bin. Bits: 00000001
Bin. Bits: 00000000
Readiness: N/A
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 041 A HW: 02E 927 770 AD
Component: GSG DSG 041 0821
Revision: 04004010 Serial number: 00000412080306
Coding: 0000020
Shop #: WSC 01279 785 00200
VCID: 102FCF5E03DDEEC488-8044
1 Fault Found:
01208 - Data Records in Control Unit Altered
000 - -
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 73E5A0D2120BB5DC15-8026
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0430
Revision: 120844 Serial number: 8P0820043AH
Shop #: WSC 00000 000 00000
VCID: 72EBA5D66D11BCD41E-8026
4 Faults Found:
00796 - Fan for Interior Temp Sensor (V42)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 61
Reset counter: 61
Mileage: 77341 km
Time Indication: 0
Date: 2018.02.14
Time: 07:26:50
Freeze Frame:
Voltage: 13.10 V
Temperature: 0.0°C
00532 - Supply Voltage B+
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 3
Reset counter: 101
Mileage: 80160 km
Time Indication: 0
Date: 2018.08.23
Time: 02:52:06
Freeze Frame:
Voltage: 9.00 V
03271 - Installation of Positioning Motor for Back Pressure Flap
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 101
Mileage: 80160 km
Time Indication: 0
Date: 2018.08.23
Time: 00:41:33
Freeze Frame:
ON
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 80162 km
Time Indication: 0
Date: 2018.08.23
Time: 01:24:01
Freeze Frame:
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007989369
Coding: E1881F01B01410004F1600001600000000085E175C010000000000000000
Shop #: WSC 06314 000 08192
VCID: 45812E0A0C1F7B6C6B-8010
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00150573
Shop #: WSC 06314
1 Fault Found:
02389 - Release Signal Transmission; Position P/N
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 80162 km
Time Indication: 0
Date: 2018.08.23
Time: 01:19:00
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP0020NU9
Coding: 0071612
VCID: 4B9518322A7B8D1CBD-801E
Subsystem 1 - Serial number: 6332DRB40663072AH
Subsystem 2 - Serial number: 6342DRB406624EA7X
Subsystem 3 - Serial number: 63528RB40337B1027
Subsystem 4 - Serial number: 63628RB40341C36AK
Subsystem 5 - Serial number: 63747RB4032732189
Subsystem 6 - Serial number: 63847RB4032749BAU
No fault code found.
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014142
Shop #: WSC 00259 210 87519
VCID: 41893A1A1837574C57-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 K HW: 8P0 920 981 K
Component: KOMBIINSTR. VDO H22 0660
Revision: D0H22003 Serial number: 224DG003104423
Coding: 0000428
Shop #: WSC 12345 123 12345
VCID: 408F3F1E133D5E4458-8014
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07B290AB7
Coding: ED807F061006022103
VCID: 306F6FDEA39DCEC4A8-8064
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H22003 Serial number: AUX7Z0GDFN409T
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0000688
VCID: 43853012022B455C45-8016
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Shop #: WSC 02069 000 90108
VCID: 366359C641F9E0F4F2-8062
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980202002186D0985054C9FC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674752796675
VCID: 35615ECA5CFFEBECFB-8060
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000688
VCID: 4487330E072542647C-8010
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H01 0270
Revision: 00H01000 Serial number: AUZ1Z3G6860102
Coding: 0730211
VCID: 3F8D3CE26EC321BC21-806A
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428B35161D314C544E-8016
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005287703
Coding: 0001222
End-------------------------(Elapsed Time: 01:59)--------------------------
www.Ross-Tech.com
Coding: 0000078
1 Fault Found:
P1652 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 40
Mileage: 80162 km
Time Indication: 0
Date: 2018.08.23
Time: 01:15:34
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 10.96 V
Bin. Bits: 00000001
Bin. Bits: 00000000
Readiness: N/A
Coding: 0000020
1 Fault Found:
000 - -
Revision: 00H11001
Coding: 0023170
1 Fault Found:
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 61
Reset counter: 61
Mileage: 77341 km
Time Indication: 0
Date: 2018.02.14
Time: 07:26:50
Freeze Frame:
Voltage: 13.10 V
Temperature: 0.0°C
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 101
Mileage: 80160 km
Time Indication: 0
Date: 2018.08.23
Time: 02:52:06
Freeze Frame:
Voltage: 9.00 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 101
Mileage: 80160 km
Time Indication: 0
Date: 2018.08.23
Time: 00:41:33
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 80162 km
Time Indication: 0
Date: 2018.08.23
Time: 01:24:01
Freeze Frame:
Coding: 00062736
Shop #: WSC 06314
Coding: 00150573
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 80162 km
Time Indication: 0
Date: 2018.08.23
Time: 01:19:00
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
Coding: 0071612
Coding: 0014142
1 Fault Found:
Coding: 0000428
Coding: 0000688
1 Fault Found:
000 - -
1 Fault Found:
Coding: 0000688
Coding: 0730211
Coding: 0000144
Coding: 0000144
Coding: 0001222
