B8 3.0TDi stock boost psi?
the fatty
Devon
Does anyone know the stock boost pressure for the 3.0TDi (CAPA)? I am trying to figure out if my car has been mapped. I have done some logs and have seen readings as follows (24psi peaks). Many thanks!
Upload 2018 9 1 19 16 51
You are better off logging the fuel injection amount as this is what is really modified in a remap. The actual amount of boost may not be much more than stock as there is plenty of spare air as standard.
Stock map injects around 64mg/str fuel between 3-4K a remapped car more like 75-80mg/str and there will be a lot more fuel injected at lower RPM. Standard 2k rpm max acceleration 35ish on a mapped car more like 65 ish.
On my CAPA injected fuel is block 102.
Reactions: the fatty
Looks like it is probably mapped looking at this log (red is RPM/100, blue is mg/stk)
Upload 2018 9 9 13 5 26
Reactions: desertstorm
