- Joined
- Oct 21, 2014
- Messages
- 197
- Reaction score
- 58
- Points
- 28
Where are the ridges on your diffuser?
There aha must of been a dodgey angle
Looks like a nice system.View attachment 174624 Thanks for the replies and will look into those boxes And this is how my exhaust system looks the first picture is the small box added later on to tone things down slightly!
Car looking very niceFinally had the car dyno’d again and it made 367hp and 345 ft/lb of torque which I’m a bit disappointed by if I’m honest..
upon speaking to my tuner he says the intake temps in his dyno cell were above 56 degrees which I’m aware would cause the car to pull some timing ? ( standard fmic )
So hopefully once I fit an aftermarket cooler the map can be tweaked..
View attachment 181869 View attachment 181870
I had 349bhp before fitting a Wagner IC, 381bhp after. Its not all about running cooler as the std IC on the later S3 is plastic and notorious for leaking boost.
I’m sure your get the power to were you want it to be.
Did you make any changes to the map? Or did you just swap out the standard for the Wagner?I had 349bhp before fitting a Wagner IC, 381bhp after. Its not all about running cooler as the std IC on the later S3 is plastic and notorious for leaking boost.
Yea I’m unsure on which to go with ideally I’d pick up a good condition 2nd hand unit or go the welly cooler route but not a fan of cutting at stuff on this it’s not the same as chopping up my old 8l
Thanks!
Mine is the later plastic one I believe being 2012 ? Really wanting to find a 2nd Hand airtec/Wagner or peron cooler but seems no one wants to sell once they fit them which I understand ..Just a straight swap, the std is notorious for leaking boost at the joints, especially the later plastic ones.
