EPC light with JB4
MattJF
Cheshire
Hi all,
Apologies if this is the wrong place - I've only recently joined so just getting used to the forum layout! I'm in nee d of some help regarding my JB4. Now, I'm aware running an JB4 isn't the best, but the majority of people don't face issues with them.
Here's the rundown: I installed my JB4 around a week ago, since then I've driven about 600 miles and it's been great, the power delivery is amazing and the car feels transformed! However, on Sunday morning my EPC light appeared and the turbo wouldn't boost at all, it felt like I was driving a 1.2 Corsa :grumpy:
I switched the car off about half a mile down the road when I could, waited a few minutes and turned the car back on. The EPC light was gone, so I thought no more! Around 8 hours later, the EPC light appeared again so I did the same and poof, EPC was gone and the turbo was boosting fine. At this point, I was worried. I scanned with OBD11 and the following errors were present:
- Manifold Abs.Pressure or Bar.Pressure (Fault code: P010700, Intermittent)
- Turbocharger Boost Sensor (A) Circ. (Fault code: P023700, Intermittent)
Towards the end of the night, the car was not drive-able. The EPC light would go off when restarting the car but pop after putting my foot down. After some help from a few kind guys on the MK7 R owner's club from Facebook and checking the graphs, they found my throttle was cutting out erratically and after modifying FOL and some other values, nothing helped.
The issues still occurred when the JB4 was on Map 0 and Map 4. I've been on Map 2 for the past week. I have since removed my JB4 and the car is fine - so I'm left wondering what the exact issue is.
Common sense would dictate that there could be a small leak somewhere and the extra boost is causing the car to throw out errors - could this be the case and if so, how would I go about finding the leak? If not, what else could this be (also considered a dodgy sensor, so I have purchased a new turbo boost sensor for the charge pipe and another pressure sensor on the manifold) but I am hesitant to fit these as I'm not too sure if they'd actually resolve the issue when the JB4 is connected.
Not too sure if George from Burger is on here, but any help would be much appreciated! If this is in the wrong place, please move and I'll make sure to post in the right place next time :thumbs up:
Thanks in advance!
Can you not turn the settings down to a lower level, similar to DTUK box, not all car will run the higher/highest
I've tried the JB4 on Map 1 and Map 2, same issue still occurs. Even with the JB4 on Map 4 (all boost settings, etc are disabled on this map) it still throws up the EPC error after putting my foot down which is what makes me think it could be a sensor (possibly on the JB4).
Reactions: monopole
Where did you get the JB4, was it an JB1 upgrade? I had similar issue with my JB4 and even map 0 didn’t help with the EPC, turned out it was a loose pin in the OBD cable connector, once checked and push back in place everything has been running perfectly since! And George is on VWV all the time or just shoot him an email if something like this came up...
No JB1 upgrade - just JB4 with bluetooth connect kit! I'll check the OBD cable connector, good shout - I have had that in and out a few times so it quite possibly could've been bent. Just sent George an email, much appreciated mate :thumbs up:
Did you sort this out? I’m having a similar problem
Not saying it’s the same but when I mapped my S3 it kept miss firing and the EPC light would come on. Changed the sparks and *touch wood* it’s not come back on since!
I fixed my issue. I opened the box to check the board and the plug was barely connected without screws. 2 new screw and it is running great.
