Rocker Cover Gasket
ScottyBee01
Edinburgh
I need to replace the rocker cover gasket due to oil leak (not major). Whats the best gasket kit to use on AGU?
Oem is always best there cheap enough from tps
Reactions: Chalkymon
I got mine from TPS Can’t remember how much mine was. You can try the parts request on here for genuine parts but I’ve found TPS to be cheaper tbh
Remember to put sealant too like picture shows.
People many times change it and then it still leaks because they did not know that sealant should be used.
You dont have to use OEM, the others are just fine too. I have the cheapest and no leaks.
For sealant I used blue one.
Reactions: Chalkymon and ScottyBee01
Thanks bud.
