Are these two Haldex controllers interchangeable?
S3 Hilife
It's an addiction
Wisbech, Cambridgeshire
Hi guys, I’m half way through swapping my Haldex controller over for a replacement. I know there are two different designs of controller, one with circlip and one with bolt head, one has recessed fluid ports one doesn’t. Sods law I get the different one as a replacement.
I’d like to know if I can fit the one with recessed ports and bolt head in place of the other type I’ve just removed. If so do I still use the new gasket as well as the rubber seals?
45ABDDBD 582F 40A0 8E2A CCCD15AA1386
Thanks in advance
Steve
Get the right seals is all... I noticed that you had the metal one in your collection of bits on your thread... you need to get the o-ring type for this replacement... just use the rubber seals and not both rubber and metal seals
Thanks I started to worry a little when I found they were different
o-ring type is an earlier version is all... they changed to the metal seal type around 2001 on... my AMK S3 is metal seal...
Ahh that’s what I suspected :) It’ll be interesting to see how the internals differ from eachother. I’m going to strip the one I removed today and have a look to try and work out why it wasn’t working
Normally the servo motor or the drive part of it at least packs up... mechanically all it does is move a valve up and down to divert the flow of hydraulic fluid... electronically its a controller for the servo motor...
Reactions: S3 Hilife
Looking at the valve assembly from the known working one, I was surprised it was working at all tbh. It was full of thick sludgy gunk. I never tested the synchron motor though, I think I probably should have really
often wonder if caught soon enough a good clean would get them serviceable again...
I still think its down to the lack of oil changes... especially on a mapped car where the haldex will be potentially more active
Definitely, this is what came out of my Haldex today
BE89AB2B 2658 4051 91BA 5A4ABE71C1B7
This was apparently replaced less than 20k miles ago by a local garage. When I pulled the pump out the strainer was clearly clogged up and the amout of sediment and sludge sat in the bottom of the housing for the pump was unreal. I suspect this caused my Haldex to stop working (or at least the pump)
Reactions: ToughlilT
