Best paint for rear brake hubs
danjh
Cheshire
Hello,
I am just wondering what paint people would suggest is the best for painting these and getting rid of the rusty rim? I've seen a lot of people suggest the POR15 paint but I am not sure which one to go for as they do accouple?
is it this? https://www.frost.co.uk/por15-rust-prev-473ml.html
Cannot believe they go rusty so quickly on a 67 plate.
IMG 2450 IMG 2452 IMG 2453
As @Gazwould said.. Get yourself some Hammerite Smooth. Either spray or brush able versions. I have used both. This time I used the spray version on this car and I think it gives a better finish.
EEAD25CA 37EB 4937 8869 BF3543CADE5E
Spray version does however requires a little more prep (to mask surrounding areas and close body work) but provides a quicker and better finish as you can add additional light coats far quicker ... (about every 15 mins vs 2 hours for brush version). But depends how good you are with a paint brush. Either 4-5 light coats with a spray can or 2 coats with the paint brush version and you are done.
Here are some pics from when I did mine about 6 weeks ago. Rears after a light rub with sandpaper and a wire wool brush. You can see rust starting on the outer edge and car had only done 1,500 miles.
A3FFA940 16BC 423E AFBB DBFC54A9D0F0
Mask brakes and disc.... just spray edge of the hub and the very centre hub and feather edge, not the main face that the wheel connects with or the bulk of the centre hub.
7665657F 3C6E 46E3 B4FB F94052D9DD57
After 2 - 3 light coats...
B9A7BAD5 02F8 44C7 AF58 74F11200ECAF
Final 5th light coat
38C0D2A9 6A76 43A3 BCDC A2814F398D04
Fronts can just be cleaned and treated with a sealant and should be ok. You can ofcourse spray them as well if you like but a bit more fiddly. I used a wheel sealant on the front brake calipers and front hubs.
2440A26D D7D2 4E2B 82D0 74A529FF4D52
6FE88BFA 7A9C 44E0 9762 43604BD00F04
Use the 15 mins drying time between coats to clean and seal the alloy wheels. I used the same Chemical guys wheel sealant Then you are all done !
B79CA098 1280 487E BEEC 8CF9B9AEF27B
C090E718 2CC0 4490 9D1B 85ACDC00AE86
Personal preference, but I add a little bit of copper grease on edge of the hub before adding wheel. ( you do not paint that bit ) and then put wheels back on.
9B98C0D1 9F0F 473D 8F98 B7716CA9C145
Then you are done for hopefully several years!
Rears sprayed.... final result.
14027A32 BF20 4886 87F1 36FD0E90E516
844C1133 DC60 4141 8667 F68B74C54F82
Front hubs just cleaned and sealed.
CE8E4715 A10D 4762 A6A2 DE96BE478C7B
20112258 9FDC 4AC4 85B6 CDC1C2A41446
Regds
Jungle
Reactions: T-800, Dunedin, dno_uk and 3 others
Not a bad price, £270 for the pair.
Much better no more rust
Reactions: Dan_DJT
