Weird radio problems (Audi Concert)
DylanJ
When I bought my car someone had installed a rubbish aftermarket radio and the rear speakers didnt work and it was poorly installed so I just bought the original Audi Concert to replace it.
It works great and all however it doesn't turn on or off with the key I have to press the volume button when i get in and out of the car to turn it off and on manually. I know that it doesn't use ignition live it uses canbus which is why Im stuck as to what to check.
Secondly theres no radio info on my trip computer its just black? My brother has the same Audi and radio and hes has the radio info and my car has the option to display it in the menu settings but it just doesn't show.
EDIT: car is a 2005 facelift sportback (with the red clocks not the black and white ones)
Sounds like the canbus wires aren't connected, 2 orange thin wires known as can hi & lo, check where they're connected too.
Reactions: DylanJ
Are they labled as CAN-L and CAN-H on the radio? Will have to have a look tomorrow the wires and loom looked and felt pretty solid though
Yeap they sure are.
So I checked the wires today and they seem solid/connected is there anything else I can check? I looked for a fuse but could only find can gateway and even so that fuse was fine
Diagnostic check tbh, but the faults tell me the canbus is the issue.
Whereabouts are you based?
I have a VCDS cable although not much experience I think I have 1 vin left. I didnt think it could diagnose the radio where would I look in VCDS just the standard scan?
