DAB radio wiring/antenna location
prits_88
ashford kent
Recently installed blacvkue dr900s 2ch dashcam and have noticed it has affected the DAB radio quite a lot. Have frequent dropouts and interferences.
This seems a known problem within the dashcam world, but i have been advised by blackvue if i route the cabling away from the DAB wiring/loom/antenna it will reduce the effect it has.
Problem i have is that i don't know where the wiring is.
Can anyone help?
thank you
Can anyone help?
thank you
DAB antenna are the top two copper strips on the tailgate glass disguised as heater elements.
I found a decent routing away from DAB antenna and posted on the S3 forum I’ll try and find the link
Sent from my iPhone using Tapatalk Pro
Ah, are you Saloon or Sportback ?
Why not just cable the wire to the left of the car so bypassing the 'black twix' thing alltogether?
Was a while back but think from memory antennas were both sides so MMI would take the signal from the side with the strongest reception.
ah i see, i will dismantle and have a gander. which feritte cores did you use? the blackvue ones? did you just put 2 at the end of the rear camera input cable?
you are correct, the antennas are on both sides.
Reactions: Rob2k68
Think I picked them up from Amazon for a 3mm or 5mm cable diameter (can’t remember) and put them close to the camera as possible (you can just see in the photo I linked to) but I also put them either side of the rubber grommet.
