1.9tdi Not Starting
DieselJake
Well-Known Member
The Internet
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front D1320
Coding: 04255
Shop #: WSC 06435
VCID: 6596418AAC75F4DFE21-51F2
3 Faults Found:
18258 - Powertrain Data Bus
P1850 - 35-00 - Missing Message from ECU
01314 - Engine Control Module
79-10 - Please Check Fault Codes - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
VCID: 5EE46E668923A70723B-5184
3 Faults Found:
00757 - Right Vent Temp Sensor (G151)
30-00 - Open or Short to Plus
00819 - High Pressure Sensor (G65)
01312 - Powertrain Data Bus
79-00 - Please Check Fault Codes
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 C
Component: KOMBI+WEGFAHRS. RB4 D14
Coding: 00400
Shop #: WSC 21215
VCID: 290E0DBA80ED10BF069-5184
WAUZZZ8E52A007313 AUZ6Z0A0079950
1 Fault Found:
49-00 - No Communications
It has oil, think I may have some corroded electrical components/box?
Any help or suggestions are greatly appreciated.
Wow, surprise NO one replied!!
Was this sorted Jake?
I know you know, but did you check very basics like battery, alternator etc? Failing that, looks like the ECU is not being nice?
Hope its sorted?
Reactions: DieselJake
Cheers, same to be honest.
Yeah all sorted now mate the box for the electronics under the bonnet had cracked (most likely when it or the ECU or the bonnet or the windscreen or something else was replaced), seems quite a common thing to go wrong, the place I took it said the had the same on an RS4 the week before (let's water in over time straight from the scuttle pannel if it's cracked).
If anyone else suffers the same this is a great guide: https://www.audi-sport.net/xf/threa...ngine-light-flashing-cause-fix-inside.143060/
I also had to replace some solenoids in the box that had corroded which is what killed it, I also previously unclogged the plenium drain plugs under the battery (which was unfortunately unrelated but a good thing to do to stop rain build up especially at the age our cars are now).
Treated my car to a few more go faster bits today so it best be ****** reliable now haha :icon thumright:
Glad you are sorted..... my tdi wont start at all.... just read the link you provided & all i get when i turn the key is an amber triangle with circle light. I fitted a new oem brake switch before all my problems started. Could this be a likely cause????
Could well be, do your brake lights still work when you try them? If your anywhere near Birmingham I can scan it or if not that would be my second port of call just to see if it's down to a lack of communication like mine or something else.
Well, glad you got it all sorted.
Thanks for the update Re: what to do if it happens to any of us. Quite easily done especially bad weather.
Haha, need to see more of your car. Some vids perhaps. :tongueclosed:
Cheers mate, I'll probably get a build thread up soon like yours, keep thinking I'm done then find something else to buy haha.
Yes, please do! You've slowly modded the HELL out of your B6 and me, like a lot of others would like to see the fruits of your labour!
