Vannhickey
Hey, first of all i wanna say, im bad on english, but ill try my best..
Got 2.5tdi Audi a6 2001, bought as AKE, but got roll cams..? also tiptronic & quattro.
Driven around 250 000km.
Problems is, its running rought on idle revs jumping little and on (service mode)? revs limited 3k.
Also On Reverse & Drive, i barely can keep it still with brake on, revs jump a bit more on thoes. After heating up a bit i might get it running steady on P and Neutral on idle, but little touch of pedal makes revs jump again.
Its giving fault codes:
01126 - Enghine Speed Signal
16-10 - Signal Outside Specifications - Intermittent
And
00513 Engine Speed Sensor (G28)
27-10 - Implausible Signal - Intermittent
So far car visited couple of workshops, even original audi service where they found out 6mm bolt inside cutted 3 of 6 flywheel pins, so no wonder it was running rought no signal on 3 pins. New Flywheel installed, same issue...
Heres parts changed so far and checked multiple times.
New VP44
New Ecu
New 3rd cylinder nozzle
New crankshaft speed sensor(got three of them)
New Transmission Fluids.
New MAF
New Flywheel
Rest of nozzles checked also, (opening preasures)
Timing checked multiple times.
Also most of wires checked.
Running same whatever you unplug.
+Cams are almost new. not worn a bit.
Thinking about transmission but what else could be broken by 6mm bolt.. (No freaking idea how it got there, when i bought car, earlier owner said its only g28 what needs to be changed..)
And
New VP44
New Ecu
New MAF
New Flywheel
