Anyone know what this warning light is about
lisaclio
Had this flashing at me and bleeping at me for the last few weeks and I want to know how to get rid of it.
Had my car in for its mot at the end of March had new pads put on the rear, still over half left on the front so with regards to brakes everything is working as it should.
I scanned it and no fault codes came up other then for my radio as it's not factory and also for the matrix heater.
Any ideas on what this could be?
That’s a fault in the brake system iirc
Offically it means Brake Pads Worn . Now that could mean your front ones ate below wha the car things they should be , might be worth taken to the garage who installed your back brales and get them to clear the fault
I thought that only the front pads have indicators in it? My car only has them in the front anyway
Verzonden vanaf mijn iPhone met Tapatalk
Firstly i would get garage who fitted the backs or did you do them to clear fault for you as you never know it might not come back
That’s front brakes too low, could be a fault with the wire being broken from the pad to the connection on the car also.
New pads are around 8mm thick if they are down to 3 or 4 mm change them after checking warning cable
Just incase you have any other lights on your dash
Reactions: mechanic69
Yes something 120 seems more realistic.
Reactions: S. and mechanic69
