Cluster Swap immo 2 to immo 3
Erikn89nl
Netherlands
I am looking to perform a wideband conversion on my AGU A3. I could have the immob defeated on the ECU and be done with it, but I was wondering if it was possible to fit a facelift cluster instead...
Anyone done this before?
Gops did this on his S3 but his was narrow band ME7... not sure what was involved but he may have written it up in his thread
Gops did this on his S3 but his was narrow band ME7... not ure what was involved but he may have written it up in his thread
Thanks, I'll have a look. I believe some compatibility issues may arise from the lack of CAN-bus in the PFL A3. Does narrowband use CAN?
only for comms on the cluster iirc and maybe the haldex too
Ok, that's good news. I checked Gops' thread but he simply states it was a matter of getting both SKCs and doing the swap, but his seems to have been immob-defeated prior to the clock swap...
Another question: if I have a used ME7.5 ECU from a random car, and get a used FL cluster from another random car, can they be made compatible in my car?
Current ECU is Immo2 as I understand it, so while I can get the SKC from the current clocks, they won't be what the new ME7.5 ECU has stored as it is Immo3...
So there's no need for the SKC off the clocks that the ME7.5 ECU is paired with?
As far as I am aware no... they should work... but you would need to code the keys too as the RFID chips are keyed in to the clocks as as well
Hmm, will probably need to buy a set of clocks + barrel + keys anyway. I doubt the old type of keys will work with the newer type cluster...
You can put new cluster into pre facelift. Not the other way around.
I could never get the other way around to code in
I’m assuming you have some type of cable to be able to read the ecu/instruments??
If yes. Go and download VAG EEPROM Programmer.
Revert to me when you’ve done that :)
Help me, Obi-Wan Kenobi, you are my only hope!
So, I've yet to find a suitable cluster (FL with kph speedo) before I do any of the above...
Anyone know what the partnumber on those should look like?
LOL
Just get any part number - just as long as it's facelift
the rest i will teach you
Reactions: <tuffty/>
Not sure what "teach you stick" is referring to, but if you need instructions on driving with a manual transmission, I only have one useful bit of advice:
Do not select 2nd instead of 4th, unless you have a fully upgraded valvetrain :)
