S3 GTX2860R gen II build
I don’t know, I am not a tuner, nor his tuner, nor do I know what injectors he plans to install for running his engine in.
Injector won't mean jack with a Garrett strapped to it mate. A/f will go crazy at 5k with stock map.
Sent from my Nexus 6 using Tapatalk
discussed this with tuner too and he said to run N75 valve not connected and just to be careful. Car will go to limb mode if push it hard this way.
Another option that I thought would be to take actuator off wastegate and keep wastegate open or half open until break-in. Problem with this is that its not really a proper break-in without engine going to boost.
I have some knowledge how to break-in but here is so lot more experience, that is why I asked for tips.
I have 630cc EV14 matched injectors waiting for tune but I have to use original injectors until I can get the car to tuner, since car wont work with big injector and normal software.
also I have 265LPH in-tank pump and adjustable FPR
5k rpm seems bit lot, I am certain engine will go lean.
oh and yeah I chose my words badly earlier about turbo. I know that turbo will make more airflow than k04. used word might :D sorry english is rusty.
Superkarl: I was thinking same. Up fuel pressure, follow AFR/EGT, log fuel and just drive carefully.
It is better car run rich than lean.
I already got home from garage but forgot my info about the oil return.
What kind of return fits to oil pan of S3? I mean angle of it or anyone have pic of their setup?
I cannot remember how far does transfer box come.
Edit: Found picture from Tuffty post.
Can just see mine there, braided line
Manifold is already installed and port matched with turbo and I have downpipe already too.
So no, not at this moment I wont buy different one.
I found WBO ECU for 50pounds so I bought it.
Now I only need to find how to pin/change the singleband o2 to wideband o2, any guides anyone?
Looking for connection guide, I have extra pins, extra o2 connector, 330hm resistors etc. just need diagram
It is AUM ecu and I have APY ecu at the moment.
Not going to use VVT, EGT or SAI
Yes until I get it registered. Then I switch to FMIC and tune it.
Thanks for referring my car as bomb, Im pretty sure it will explode too with my luck :D
I'm not talking about your car, even stock turbos potentially act like a bomb too if faulty or mapped incorrectly, they can instantly break a car.
Tried to be funny but failed...
I am taking all precautions with car, not going to let it blow. I wasted lot of money already on it.
again: I ask alot and most might make me look like noob but I have experience with building cars. Just been over 10 year gap from last build and here is lot more info and experience than trying to scrape scattered all over internet(and most of it is inaccurate)
Nothing wrong with asking questions :)
Running on SMICs with the turbo you have will be ok as long as you are literally just cruising about and bedding in... I wouldn't do any sustained loaded runs else the IAT's will rocket...
Anyhoo... stick to std injectors for now and unplug the N75 electrically... this will run actuator pressure only (what is it btw?) and keep the revs below 5k.... should be enough to load up the engine with a bit of boost to get the rings bedded in...
Use a mineral based oil or running in oil... change the oil and filter after the first 50 miles... keep running mineral oil until at least 500miles then run the oil you plan to run going forward...
I changed mine again at 200miles then changed to fully synth after 500 miles ready for mapping
Oil and filter changes are cheaper than rebuilding engines so change as often as you feel... the bedding in process is pretty much sorted in the first 50miles anyway but still gonna be a bit of swarf kicking about for a while...
I would also be logging during your running in miles just to get a feel for airflow/fuelling/afr... running on std injectors is fine but if you are still on narrow band then ecu and you will be blind to AFR under load...
Are you planning to do the wideband conversion first?... personally I would do that... that way you will at least see AFR... I would also advise using VVT and EGT... these are very useful things to have... VVT will help with spool too...
We have here yearly check-ups on car by law and I cannot change the intercooler before I have got it through that. After it Im going to change for FMIC
Actuator is working at 1 bar
I got 15w-40 mineral oil ready for 2 changes and new filters and Castrol 5w-30 edge oil after 500miles.
Im leaning over to do wideband conversion but I have to skip VVT and EGT this time. My head doesnt have VVT so I would have to open up engine again and find VVT assembly and build harness for it
Interesting to hear that VVT helps spool.
EGT Im not sure how to fit it to that manifold but I was planning to put in EGT meter on DP since I got one already(btw where would be optimal spot for EGT sensor on dp?)
Also Im bit scared of EGT breaking and parts going into my new turbo, if fit to manifold.
Also going to put in wideband O2 sensor to DP and meter also, to see what is happening on AFR all the time. Got LSU 4.2 and LSU 4.9(wont work on ME7 I think) sitting on self
Yes I will keep standart injectors since car wont most likely even start with 630 ones.
I hope I can find program and IMMO delete for the ecu and diagram also. I got programming cables and galletto cable but Im hesitant to try it, since I really have no clue how to tune ME7.x (have tuned VEMS and megasquirt in past approx 10 years ago)
For logging I bought carport program earlier which seems to work great.
EGT is fine in the DP just after the turbine... its where mine is and where its fitted for any BT build I have been involved in... just need to remember to alter the relevant tables to lower the EGT protection trigger temp as its will be cooler there than in the normal hotside position
VVT and EGT will need coding out in the map then... you will not be able to tune AFR properly without coding out EGT
LSU 4.2 will be required for ME7.5
It will start with the 630's but ECU will pull fuel and it will run mega rich potentially causing bore wash... not something you want at all..
If running narrowband band at least have AFR to monitor then thats ok but watch it like a hawk until you are sure it can deal with the the airflow the new turbo is producing...
You dont happen to have part number for EGT? Im checking the price, since it would be easy to install now.
Edit: well except I dont have a place for in in wiring loom so I guess Im not going to install it..
Thank you Tuffty! what do I owe you? :)
to confirm, lambda wires go to pins:
5, 51, 52, 70, 71
I found APY ecu pinout but it says "simos" and it makes me confused? check pictures.
if that is right, I need to add pins only 52, 71 to ecu and rewire rest to new lambda, is this correct?
EDIT: picture of APY added..Apy Lambda
I do appreciate your advice and regarding what you said, I am going to ask is the S4 maf really needed.
That is what I thought about the TIP.
Thank you!
Now I have to figure out what intercooler to use since here you cannot cut into the crash bar (against law to cut protective parts of car)
Tip? Whats this short for?
Sent from my LG-M160 using Tapatalk
Would Audi TT BAM loom fit to my car?
Seems it might fit but is it compatible (engine loom) with rest of car and where does it "cut"? I mean by cut, connect to compartment loom
you really don't need a full loom to do the conversion...
Not done one myself but from the ones I have seen done at bills its just a case of running a few wires and making sure you add an engine control relay if yours hasn't got one...
The TT loom will be a bit of a ball ache to fit as there are subtle differences... chopping it about could cause more issues than it solves...
APY ecu diagram...
https://drive.google.com/open?id=0B4uWtQA4MHkUMXd2ZVl1ZXM0X1E
APY ecu diagram...
Damn me! I made offer for 50 pounds for BAM loom, hopefully they dont agree :D again im too hasty...
Engine control relay? do you mean Motronic current supply relay (J271) ?
hmm it doesnt show up on wiring diagram. only is SAI relay.
Tuffty could you ask Bill does he have a guide for wiring? Now im worried about the relay.
Tomorrow I might get to see the car and have to check what relays are installed.
I could but I doubt he will post it...
A google search for "J271 engine relay wiring" may help... try this for starters...
http://newbeetle.org/forums/1-8-lit...-ecu-relay-j271-1-8t-cranks-but-no-start.html
This is assuming you don't have one of course... have you looked?
Reactions: andrew_wright
Im pretty sure there is not one, since I dont remember seeing it on engine compartment. Going to confirm it tomorrow.
I just cannot find it on wiring diagrams either. Maybe its way newer s3 that has this?
mine is 9/1999 manufactured
Oh what joy we have ahead of us during this easter :D
on picture i noticed the relay box, going to see tomorrow what is inside of it.
Engine is assembled, missing only turbocharger and its hoses. Car is just waiting engine. Hopefully I get lot done during 5day period.
It sucks my car is so far from any shop, that takes 2 hours to get something if missing...
Next week I have the BAM engine loom and maybe going to strip it. Tuffty what problems you think there would be if I used the whole loom? any quesses?
IMG 20180325 171207 26734096 10208545999006282 5074290969730221172 n
now I could add EGT too but is it lot help?
btw Tuffty I read your topic quickly, what is the program you are using on it? I have same fuel pressure sensor that you do and would like to log it too.
I have a different ECU altogether....
ran in a bit of trouble with clutch.
Racing company sold me Sachs SRE -789 pressure plate for single-mass flywheel.
My SMF kit is valeo and when I put the sachs pressure plate on it, I noticed that its spring plates are approx 5mm lower than valeos own.
Plan was to use valeo SMF+clutch plate+Sachs SRE pressure plate but Im not sure would it work with that height difference.
Also Sachs has bigger holes for bolts.
In other hand worn clutch kit might be easily over 5mm lower because of disk wear.
I have quite new LUK clutch kit in car but its DMF, the sachs pressure plate seems to fit to it but it is thicker about 3-4mm
-789 pressure plate is marked on Sachs site as "racing only" and is supplied usually with Sachs SMF and organic or sintered paddle plate.
Does anyone here have similiar setups on clutch?
I remember that on 228mm clutch you could use Sachs SRE pressure plate only and it would hold very much more torque than stock but I guess it is not same on 240mm.
Has anyone used just that same pressure plate on some other or similiar clutch setup?
Yeah I know that going cheapskate on that is idiotic but I really dont have 700€ for Sachs setup..
Forgot to mention that I got a tune for my fuel etc. setup so I dont have to worry about going lean anymore. Its calibrate for my car. Now I just need to get the clutch right and get the new ecu from mail and start to break-in
That damn clutch just set me back argh... I read somewhere that using sachs paddle(?) disk with original dmf and luk pressure plate would be good for 500hp and 400ftlbs. Can anyone confirm this?
Was it mapped on a dyno?
It is from a car that has been mapped on dyno, similiar setup. It is not 100% perfect but at least this should not go lean and dont have to worry so lot vs normal tune+injectors.
EDIT: forgot to say that N75 is disabled from this program so only actuator working.
I ordered PLX AFR to monitor afr
Tuffty you have LUK dmf+pressure plate and 4-paddle Sachs on your car right?
I dont think I can use that Sachs SRE pressure plate with my SMF since with sachs setup (smf+plate+SRE cover) the middle springs are 5-10mm lower than with the cover that came with the smf kit.
I called seller and asked if its possible to change the pressure plate to 4-paddle disk but he wanted to ask sachs if it will fit to my SMF setup
I have DMF luk kit which is almost new so just changing the 4-paddle disk would save me time.
