I really appreciate your opinion and its good to get things right before I assemble poorly made motor to car
"drop-in" as can be used as replacement for original piston.
they are made from 4032 apparently
"Wössner pistons feature a unique Moly coating on the skirts and a grade of 4032 Alloy (T6)"
Moly coating is gone thought, Cant see lot of it left on skirt
Wössner are regarded by Europe's leading motor sport engine builders as being the piston of choice when building an engine not only to perform, but to withstand the stresses and duress's of competition life. Wössner pistons feature a unique Moly coating on the skirts and a grade of 4032 Alloy (T6) which allows the engine builder to run a closer piston to bore tolerance then he might do on another make of piston. This helps remove the slapping noise during cold start, common place among engines running forged pistons due to larger then OE bore clearances. The crowns of the pistons are also mirror polished to better resist detonation on a high performance engine. Mirror polishing allows a more even spread of heat inside the chamber which will help prevent "hot spots" on piston crowns.
Reccomended Piston to bore clearance 0.07"
