T
Some insurance companies now require cameras to be professionally fitted in order to guarantee functionality and safety.Professionaly fitted ?
What's so complicated about tucking a wire and adding a fuse tap ?
How much would you charge to fit the Thinkware F800 pro,not sure to go with 1 or2 cameras?Some insurance companies now require cameras to be professionally fitted in order to guarantee functionality and safety.
Personally I am all for people having a go themselves, but I can understand where the insurance companies are coming from. Tucking cables is often not the best way as you might be routing your wire in front of an airbag, which if ignited would most probably stop the camera from working and thus not providing the footage your policy might depend on. An installer should be popping trim and routing safe. A “cross over” might also prevent an airbag from deploying the way that it should. A professional will also only mount the cameras in safe places for both field of view and heat generation.Guess they get a back hander..
I have the dual channel system in my car. Rick solid with zero dab issues. I always suggest dual channel.How much would you charge to fit the Thinkware F800 pro,not sure to go with 1 or2 cameras?
Email sentI have the dual channel system in my car. Rick solid with zero dab issues. I always suggest dual channel.
If you can fire an email over to hello@vagcarcoding.com we can sort out the details.
So at night say with little street lighting it's good like infrared ?
"I had all professionally installed as I simply don't have the time or patience to do it myself. Saying it's an easy quick job is mad, not if it's done properly. Takes a few hours."
Micro usb to dashcam , tuck wire , ground black , insert fuse tap .
BlackVue DR750S dual cam with a dedicated battery for parking mode is a great option. Lots of improvements over the older 650S.
Did you self-install? Looking at this for my RS3 when it comes. Also potentially interested in the IR version, except £££...
Link?I did mate it’s pretty straight forward - some good guides on the web one on the S3 section.
Sent from my iPhone using Tapatalk Pro
Link?
Sent from my HTC One M9 using Tapatalk
