Any help with ideas of things to look into before I torch it and buy something else
Audi A3 2.0 TDI 2005 BKD
About once a week my car will not start it turns over but won't fire up, I let it sit for a day or two and then try again and it will start up. This problem is starting to get pretty annoying as its made me late for work a few to many times now.
I've checked the fuel is going past the filter, checked the ECU grounding straps, checked cranking speed which looks good but don't know what speed .its actually supposed to be? I hooked it up to VCDS Lite but no fault codes present.
When it does eventually start up it runs pretty rough producing a few clouds out the back but a 5 min drive around the houses sorts it out, the rest of the time it runs fine no problems at all. Its been to a good indy garage but as the starting issue didn't happen when it was there they found no faults.
Has anyone had a similar issue, know something I should check or look for on VCDS?
Thanks for any help.
