phantom_s3
I've swapped these over on my RS3 fans are much better, can you adjust the spray/jets if so how ?
The fan jets I have are the same design as the standard units in that they have no Torx to adjust their aim. So, as above question, how do you adjust the jets? I have tried the good old way with a pin but they don't want to move.I've swapped these over on my RS3 fans are much better, can you adjust the spray/jets if so how ?
I've decided that the
three jets clean the windows just fine.
Hi do you still have them? if they are in good condition and fit a 2018 S3 I would be interested in buying them?I have changed mine back to the three jets after about 6 months with the fans as I found that the jets clean better than the fans. The fans don't seem to put so much water on the screen but glad I tried them to get it out of my system!
There's a cable that plugs into the part so you just unplug it from the existing ones and plug into new ones.I hear alot of talk of 'heated' how are the part numbers listed above show or connect via some heat element?
Or the part number people are buying are just fan sprayed?
Sent from my ZTE A2017G using Tapatalk
What's the part number for the four flying hedgehogs?I don’t tend to worry myself over the delivery of water to my windscreen.
As long as the old H2O hits the screen on demand I couldn’t give a monkeys whether it’s through a jet, a fan or even if four flying hedgehogs launch themselves from under the bonnet to drop water bombs on it.
I’d love to have other people’s worries![]()
Mine too but I’d rather not talk about it as it’s a bit of a prickly subject.They scratched my windscreen, I’m saving for the baby bunny rabbits because they also give the windscreen a wipe too on the way past if your going fast enough, apparently?
SQ5
Thanks. Will have a look into this when I order a set.There's a cable that plugs into the part so you just unplug it from the existing ones and plug into new ones.
The part number should say of its heated or not.
I just went with heated washers from an A6, best of both worlds with jets and fans. Part nos:
AG0955988A
AG0955987A
Take a picture of your existing ones and we might be able to say yes or no.Don’t suppose anybody would no if these are a direct fit on a 2013 Q5?
SQ5
Thanks, I’ll do it tomorrow
SQ5
Looks basically the same, though not sure about the cable for the heated part, is it the same to the one I posted a few posts up?
Looks identical to the ones I replaced on my 2016 S3.
Hi where can i buy these nozzles from?
I just asked https://www.ebay.co.uk/usr/audisytner to list the 2 items below.£21.50 inc postageHi where can i buy these nozzles from?
Left - 4G0955987A
Right - 4G0955988A
Could also use the parts request form on here
Just to clarify, I meant to say... I asked them to list the items (a month ago) when I wanted to purchase them.. so you could send them a message too if you wish for them to re-list themThank you , I will order as soon as they list the items
