Help please
Liber_A4_te
Hello Everyone
Hoping you can assist me with my troubles with the HVAC system on my Audi A4 SE 2.0 B8. I have hot air blowing out of the passenger side vents all the time, regardless of what temperature is selected on the heater display. Driver/Centre driver vents all ok. Actions taken so far are as follows :
* VCDS run and retrieved the below fault codes (V108 looks to be a failed unit so i can replace this, have one ready to go in).
* Basic Settings accessed and attempted to run calibration on channels 001,002. All retrieved ERROR.
VCDS Report
Code:
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 M HW: 8T2 820 043 M
Component: KLIMA 3 ZONEN H05 0120
Revision: D0000000 Serial number: 0112.03.080130
Coding: 34040000
Shop #: WSC 06325 000 00000
VCID: 3C21CA149663E927469-8068
4 Faults Found:
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 167339 km
Time Indication: 0
Date: 2017.12.27
Time: 12:32:05
00711 - Left Footwell Flap Positioning Motor (V108)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 167339 km
Time Indication: 0
Date: 2017.12.27
Time: 12:34:02
Freeze Frame:
Voltage: 13.50 V
Temperature: 12.0°C
Temperature: 4.0°C
Count: 12228
Count: 11184
01809 - Actuating Motor for Temperature Flap; Left (V158)
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 167339 km
Time Indication: 0
Date: 2017.12.27
Time: 12:39:20
Freeze Frame:
Voltage: 13.90 V
Temperature: 12.0°C
Temperature: 4.0°C
Count: 10000
Count: 0
01187 - Rear Temperature Flap Positioning Motor (V137)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 106
Mileage: 167339 km
Time Indication: 0
Date: 2017.12.27
Time: 12:46:03
Freeze Frame:
Voltage: 14.00 V
Temperature: 14.0°C
Temperature: 5.0°C
Count: 10000
Count: 5357
Any assistance would be great :)
Sent from my F8331 using Tapatalk
