Hello All,
I need to replace the battery on my MY61 S3, without Start/Stop. Reading through the forum the Varta E44 Silver Dynamic (77AH - 780 CCA) is highly recommended. It's a 096 battery which the S3 requires.
The car is taking longer to crank over but I also have a VCDS 00907 - Intervention Load Management error. I know the weather won't be helping but I suspect the Dash-Cam (in parking mode) may be contributing to this too.
The existing battery is the original so I'll look to replace.
From all the threads, what I can't decipher is whether I need to code the new battery via VDCS or if it's fit & forget. Any help on if it requires coding and how to code would be greatly appreciated.
Thank you!
Sam
Thank you!
Sam
