VaguelyAmused
- Joined
- Jul 2, 2017
- Messages
- 10
- Reaction score
- 6
- Points
- 3
Hi all,
It's been a 6 month costly roller-coaster of ownership so far, 2004 B6 S4, and this latest issue has me (and the garage) at a loss. I'm now pitching the heart against the mind to decide how much longer to really keep going before calling it a day and retiring her.
A recent "development" in the symptoms makes it probably specific enough an issue to ask you lovely people if anyone has come across this before - its really a plea to save what remains of my hair! I don't think I can bring myself to walk away from her without knowing for sure what it is but that in itself may break me.
Anyway less of the X-Factor style prologue, on to the issue:
I get a buzzing noise from the front/engine area that comes in most noticeable at 2100rpm and then steadily gets worse as the revs rise until 3200rpm when it then goes away, through the rest of the rev range upwards she sounds absolutely fine. When I then let it drop down through the revs again, the noise doesn't come back until they drop to 2100rpm. When changing up, if I blip the throttle to above 3200rpm to kill the noise and then keep it above 2100rpm through the gears you would think it is all fine. Let it drop below 2100rpm and the noise comes back, up until 3200rpm. Seems to be from the left hand bank of the engine as looking at it, right hand sounds fine (although experience with the alternator bearing failing teaches me horrible, horrible noises can sound like they are coming from somewhere they aren't). Garage has had a look, sump off, stethoscopes and boroscopes out but no damage found, comment was just bearing shells look worn (engine has done 147K, but timing chains/tensioners at 125K).
I'm not sure if the noise only comes in at 2100rpm, or whether being in the cabin is sound proofing enough not to hear it at lower revs, I need to get out and around the engine bay with a mate on the gas pedal). Certainly when hitting 3200rpm to clear the noise and dropping down the revs, 2100rpm is very definitely the point the noise "switches" back on.
Various things pop up in the search, sheered tensioner bolt again, CATs, exhaust (its a Milltek resonated cat back), hyrdaulic lifters, timing chain tensioners but videos I can find on youtube don't really match with the noise I'm getting, and the garage checked for sheered bolts and would have checked the CATs and obvious things (surely, before going as far as taking the sump off!?) The noise itself is quite high frequency, and quite "growly".
Recent alternator change including tensioner and pulley, and then back again for a sheered tensioner pulley bolt a few weeks later. This issue came about 2 days after that :-(
There are a few specialist garages that tune Audi's near me (Poole, Dorset) so I may take it in and see if they mind coming out in it with me for a minute and give me their thoughts, but if anyone here has come across these sorts of symptoms before that could shed some light on what is going on, and perhaps more importantly has had the patience to read through my waffle I would owe you my sanity and my hair.
Thanks all
Chris
Thanks all
Chris
