So got it on the vcds tonight and it brought up the following faults:
(And advice or comments welcome guys)
Monday,11,December,
2017,19:33:28:
48597
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version:
17.8.1.0 (x64)
Data version:
20171130 DS
276.6
www.Ross-Tech.com
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 56
VIN: WAUZZZ8P37A
177100 Mileage:
201560km
-125243miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK
0000
08-Auto HVAC -- Status: OK
0000
09-Cent. Elect. -- Status: OK
0000
15-Airbags -- Status: OK
0000
16-Steering wheel -- Status: OK
0000
17-Instruments -- Status: OK
0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK
0000
25-Immobilizer -- Status: OK
0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Sporadic communication error
1000
46-Central Conv. -- Status: OK
0000
47-Sound System -- Status: OK
0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK
0000
Address 01: Engine Labels: 03G
-906-018-BMN.clb
Part No SW: 03G
906 018 DN HW: 03G
906 018 DN
Component: R4 2.0l PPD
1.2 1247
Revision: --H42--- Serial number: AUX7Z0G1FNS00W
Coding:
0000172
Shop #: WSC 00656 210 91840
VCID: 74ED9F0E
1706FAE
685-8020
8 Faults Found:
000665 - Boost Pressure Regulation
P
0299 - 006 - Control Range Not Reached - Intermittent - MIL ON
Freeze Frame:
Fault Status:
10100001
Fault Priority: 5
Fault Frequency: 34
Reset counter: 40
Mileage:
201529 km
Time Indication: 0
Date:
2017.11.29
Time: 17:59:57
Freeze Frame:
RPM:
3104 /min
Torque:
192.0 Nm
Speed: 43.0 km/h
99.45 %
Voltage:
13.79 V
Pressure:
2492.1 mbar
Pressure:
1278.0 mbar
000258 - Mass Air Flow Sensor (G70)
P
0102 - 007 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 5
Fault Frequency: 9
Reset counter: 40
Mileage:
201561 km
Time Indication: 0
Date:
2017.12.02
Time: 06:48:39
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage:
13.90 V
Mass Air / Rev.:
893.8 mg/str
Mass Air / Rev.: 0.0 mg/str
001648 - Glow Plug Module 1; Glow Plug Circuit
P
0670 - 007 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status:
00000010
Fault Priority: 1
Fault Frequency: 2
Reset counter: 34
Mileage:
201534 km
Time Indication: 0
Date:
2017.12.02
Time: 00:09:13
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage:
12.54 V
Bin. Bits: 00110000
Temperature: 10.0°C
001649 - Cylinder 1 Glow Plug Circuit (Q10)
P
0671 - 006 - Electrical Fault - Intermittent
Freeze Frame:
Fault Status:
00000001
Fault Priority: 1
Fault Frequency: 2
Reset counter: 34
Mileage:
201534 km
Time Indication: 0
Date:
2017.12.02
Time: 00:09:13
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage:
12.54 V
Bin. Bits: 00110000
Temperature: 10.0°C
001650 - Cylinder 2 Glow Plug Circuit (Q11)
P
0672 - 006 - Electrical Fault - Intermittent
Freeze Frame:
Fault Status:
00000001
Fault Priority: 1
Fault Frequency: 2
Reset counter: 34
Mileage:
201534 km
Time Indication: 0
Date:
2017.12.02
Time: 00:09:13
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage:
12.54 V
Bin. Bits: 00110000
Temperature: 10.0°C
001651 - Cylinder 3 Glow Plug Circuit (Q12)
P
0673 - 006 - Electrical Fault - Intermittent
Freeze Frame:
Fault Status:
00000001
Fault Priority: 1
Fault Frequency: 2
Reset counter: 34
Mileage:
201534 km
Time Indication: 0
Date:
2017.12.02
Time: 00:09:13
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage:
12.54 V
Bin. Bits: 00110000
Temperature: 10.0°C
001652 - Cylinder 4 Glow Plug Circuit (Q13)
P
0674 - 006 - Electrical Fault - Intermittent
Freeze Frame:
Fault Status:
00000001
Fault Priority: 1
Fault Frequency: 2
Reset counter: 34
Mileage:
201534 km
Time Indication: 0
Date:
2017.12.02
Time: 00:09:13
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage:
12.54 V
Bin. Bits: 00110000
Temperature: 10.0°C
000257 - Mass Air Flow Sensor (G70)
P
0101 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status:
00000001
Fault Priority: 1
Fault Frequency: 2
Reset counter: 40
Mileage:
201541 km
Time Indication: 0
Date:
2017.12.02
Time: 01:19:02
Freeze Frame:
RPM:
1952 /min
Torque: 0.0 Nm
Speed: 43.0 km/h
Temperature: 11.0°C
Pressure:
1001.1 mbar
Text: 64 kg/h
(no units): 1.64
Readiness: N/A
Address 03: ABS Brakes Labels: 1K
0-907-379-MK60-A.lbl
Part No SW: 1K
0 907 379 AB HW: 1K
0 907 379 AB
Component: ESP 4MOTION MK
60 0102
Revision: 00H
13001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 72E
199166D12F4D
697-8026
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
012 - Electrical Fault in Circuit - Intermittent
Address 08: Auto HVAC Labels: 8P
0-820-043.lbl
Part No SW: 8P
0 820 043 AC HW: 8P
0 820 043 AC
Component: KlimavollautomatH
19 0360
Revision:
107909 Serial number: 8P
0820043AC
Shop #: WSC 00000 000 00000
VCID: 6DDB8A6A742C2B2E4A
-8038
No fault code found.
Address 09: Cent. Elect. Labels:. 8P
0-907-279-23-H.lbl
Part No SW: 8P
0 907 279 F HW: 8P
0 907 279F
Component: Bordnetz-SG H
43 1201
Revision: 00H
43000 Serial number: 00000006763949
Coding:
01884F07A014100000000000000000000008FE175C
0100
Shop #: WSC 06314 000 08192
VCID:
408503DE133E
1646D
1-8014
Subsystem 1 - Part No: 8P
2 955 119 E Labels: 1KX
-955-119.CLB
Component: Wischer AU350 H
01 0130
Coding:
00062736
Shop #: WSC
06314
Address 15: Airbags Labels: 8P
0-959-655-94.lbl
Part No SW: 8P
0 959 655 H HW: 8P
0 959 655H
Component: Airbag 9.41 H
13 4220
Revision: 91H
13422 Serial number: 0037W0G14KKH
Coding: 0071612
VCID:
479718C
23610217E
10-8012
Subsystem 1 - Serial number:
63328RB
4021C3A9ET
Subsystem 2 - Serial number:
63428RB
4021ADE97Z
Subsystem 3 - Serial number:
63528RB
4021C3AC6Q
Subsystem 4 - Serial number:
63628RB
4021ADE51R
Subsystem 5 - Serial number:
63729RB
40221167EG
Subsystem 6 - Serial number:
63829RB
4022116062
Address 16: Steering wheel Labels: 1K
0-953-549-MY8.lbl
Part No SW: 1K
0 953 549 AH HW: 1K
0 953 549 AH
Component: J
0527 036 0070
Coding:
0000012
VCID: 78F5AB3E0B6E9E86A
9-802C
Address 17: Instruments Labels: 8P
0-920-xxx-17-MY7.lbl
Part No SW: 8P
0 920 981 F HW: 8P
0 920 981F
Component: KOMBIINSTR. VDO H
20 0570
Revision: D0H
20004 Serial number:
2241G004015932
Coding:
0005418
Shop #: WSC 54503 067 57207
VCID: 3B7F
74327AD
8759E
84-806E
Address 19: CAN Gateway Labels:. 1K
0-907-530-V2.clb
Part No SW: 1K
0 907 530 K HW: 1K
0 907 951
Component: J533__Gateway H
12 0170
Revision: H12 Serial number: 33001072130234
Coding: BD0F034207000101
Shop #: WSC 06314 123 12345
VCID: 2F
675062BEA
0993E
38-807A
1 Fault Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 133
Mileage:
201534 km
Time Indication: 0
Date:
2017.12.02
Time: 00:04:06
Address 22: AWD Labels: 1K
0-907-554.lbl
Part No: 1K
0 907 554 L
Component: Haldex 4Motion
0116
Coding:
0000001
VCID:
3669650641FAA8F67B
-8062
Address 25: Immobilizer Labels: 1K
0-920-xxx-25.clb
Part No SW: 8P
0 920 981 F HW: 8P
0 920 981F
20 0570
Revision: D0H
20004 Serial number: AUX7Z0G1FNS00W
Shop #: WSC 00899 210 92898
VCID: 3B7F
74327AD
8759E
84-806E
Address 42: Door Elect, Driver Labels: 8P
0-959-801-MIN2.lbl
Part No: 8P
0 959 801 H
Component: Tuer-SG
020 0090
Coding:
0000560
VCID:
408503DE133E
1646D
1-8014
2 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx
-909-144-G2V3.clb
Part No: 1K
2 909 144 L
Component: EPS_ZFLS Kl.079 H
07 1806
Shop #: WSC 02069 000 90108
VCID: 356B620A5CFCA3EE
72-8060
Address 46: Central Conv. Labels: 8P
0-959-433.lbl
Part No: 8P
0 959 433 F
Component: KSG H
08 0070
Coding: 9980202002186D
298505489AC637
VCID: 3F
8700226EC069BEA
8-806A
Subsystem 1 - Part No: 1K
0 951 605 C
Component: LIN BACKUP HORN H
03 1301
Subsystem 2 - Part No: 1K
0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P
0 951 177
Component: Innenraumueberw.H
04 0020
Address 47: Sound System Labels: 8Px
-035-382.lbl
Part No SW: 8P
3 035 382 HW: 8P
3 035 382
Component: AB2 SUBWOOFERBOXH
27 0160
Revision:
00005 Serial number: 30659635756335
VCID: 70E
5931E631EC6C
661-8024
Address 52: Door Elect, Pass. Labels: 8P
0-959-802-MIN2.lbl
Part No: 8P
0 959 802 H
Component: Tuer-SG
020 0090
Coding:
0000560
VCID:
418306DA
18341F4EDE
-8014
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 G HW: 8P0 035 186 G
Component: R Concert2+ H
16 0221
Revision: 00H
16000 Serial number: AUZ1Z3G
9090511
Coding: 0010311
VCID:
3669650641FAA8F67B
-8062
End-------------------------(Elapsed Time: 01:57)--------------------------
Sent from
Mail for Windows 10
This email has been checked for viruses by AVG antivirus software.
www.avg.com
