A6 4.2 Throttle
AndyV8
recently my 4.2 feels strange under depression of the throttle. It’s as if it’s not responding and over revs giving a sluggish change but if you lift the pedal slightly then push its normal. Had an issue recently where the ABS and ESP lights were coming on. VCDS said brake switch across eng,trans and abs modules. Could this be connected ? ABS/ESP issue has gone now but sluggish take off still there ?
ESP and Brake it co operate if which one was error will show together on dash board .
1. brake check
2.switch check
3.abs sensor check
4.abs module check.
Same case solved.
ESP Fault Solved!
Finally I took my A8 to a shop to be looked at. The error I was getting was a random ESP Fault that would turn off my cruise control, traction control and along with an annoying beep. So i took it to a European car shop and had it looked at, and only problem seemed to be the brake light switch. Still have the original battery in the car, which was reading low voltage so had that replaced as well. Just in case anyone else comes across this problem here's your fix
The brake light switch was only $22, and the battery was an unfortunate $190 a nice interstate battery though . $39 installed and coded.
Cheers!
Replaced the battery and FSA. Got a new switch, Euros gave me wrong one, so I tested the old one with a multi meter, seemed ok. Took the plunge and opened both, contacts on the plate for the switch on the old one worn. Took the plate from the new one, rebuilt, tested ok. Fitted it and scanned with VCDS. Ran the tests through the measuring blocks all passed. Carried out a test drive. Throttle response now immediate and cruise control can be engaged ! New switch on order as repair is a bit non standard !
I was £12 for battery and £9 for switch. Labour was me !
1.Battery Get borrow from someone.
2.Switch to check on off by multimeter. (Ought to be 0 ohme.)
In pic. resistance value of wheel sensor.
Best regard.
Hi, as stated in my last post it’s all fixed now. New battery and replacement brake switch.
So now what error.
It still show ABS EPS?
Cheers.
