No DPF light? 2010
Shiz94
I've never seen the DPF light come on (fingers crossed) is there a chance it has been mapped out ? Owners manual shows it should have one. I get the normal cycle increased RPM fans running. Ive cycled through the DIS warning lamps nothing there. I've carried out output test on the dials nothing there also carried out a specific test for the lamp on VCDS and it showed as running but nothing came up. I can view all relevant data e.g soot load, time since regen, distance since last regen everything shows it's fine. Do the 2010 cr140 have it or did Audi forget to install it on mine LOL or has my cluster been swapped out!!
Hi, no there is no DPF light. If you get a fault it brings the management light on.
Reactions: Shiz94
Thanks for confirming this , seems stupid when the old pd170 had a separate light
