OEM Xenon Headlight Retrofit Progress!
Adomas G
Member
Enniskillen
So, a few weeks ago I managed to get hold of a pair of original xenon headlights for my 2006 A3 off eBay. I thought £120 was a little cheap for a pair of two bare units, I was hoping no brackets were broken and internals were all ok. When they finally arrived, to my amazement, the seller also included ballasts, ignitors and even a pair of healthy Philips bulbs :blink: an absolute steal for the price, what do you think?
Anyways, the headlights were a straight swap- since it was a non-DLR, single-beam unit, the connectors matched up and the xenons are perfectly functional! Well, kind of.
Strangely, when the ignition is on, they fire up no problem- they work with high beams and are otherwise perfect. Once the engine is started, you simply do not touch them. Flash highs? They go crazy. Turn low beams off and on again? They go crazy again. They begin flickering rapidly and I was told this was due to incorrect voltage supplied to the ballast and the bulbs were failing to ignite- a coding issue that I will resolve soon with a local mechanic who happens to have VAG-COM. Most of my driving is during the day so it's a rather minor problem.
Next step was to retrofit the headlight washers. I got hold of two jets+caps of same colour as my A3 for £50, a pump for £10 and piping, clips, joints etc. for £5. Why not just buy a bumper with pre-cut holes? I live in N. Ireland, the shipping costs will outweigh the cost of the bumper itself. My A3 is red, and most red cars suffer from peeling clear coat on front bumper- and since I am preparing to have it repainted soon, I was not afraid to do some hackery :) (which is why you shouldn't use this as a tutorial on your fresh shiny bumper!)
After the bumper was removed, the first step was to un-plastic-weld the subframe. I simply used a stanley knife and sliced of the top of the weld. You can notice on the bottom centre of the picture there is a mount for the sprayer jet already. Handy!
After removing each spot (about 10-15 for each side) you can see the clear marking where the washer cap hole should be:
The cap fits perfectly with a couple of mm free on each side:
I used a dremel rotary tool and carefully went around the marking, making sure not to go over the edge. Again, if I messed it up, I wouldn't care as the bumper is not in pristine condition and will get repaired soon. (for some reason online uploader flips every second image upside down).
Meanwhile, the jets bolt right on to the subframe.
The holes on the bumper looked a little rough (as you'd expect after drilling through plastic), but some careful filing around the edges, both inside and outside, and here is the semi-finished result :) I used a sealant called SealFix to secure the subframe back to the bumper, which clipped back on nicely. SealFix is essentially glue and silicone in one, really useful stuff.
As you can see, the edges are a little rough and the gap is slightly larger than usual. A bit of sanding and maybe some body filler while repainting the bumper should fix it!
On to the next stage- the washers.
I removed the washer fluid reservoir and drilled a hole in it, fit a rubber grommet that came with the pump and it fit like a glove.
I have wired the pump with a relay that's connected to low beam headlight and windscreen washer pump- meaning the headlight washers will only work when the headlights are on and when the windscreen wiper lever is pulled. I could not source the original wiring to make it go through fusebox, ECU etc. and whilst it may be a temporary solution, it works perfectly for now.
One thing that baffled the heck out of me was that upon initial wiring setup, the sprayers would come out every time the headlights were flicked on. It took me an hour to find out that the headlight washer pump has a constant +12V supply and the ECU switches its ground on, hence every time the headlights were turned on, they would complete the circuit within the relay and since one of the pins is grounded, the jets would spray constantly. Strange! A quick rewire solved the problem.
The accessories were purchased at a local motor factor- 6 jubilee clips, 3m of PVC hose and a T-joint. The pipe began as a single 20-25cm piece from the pump, then branched out to the two jets via the T-joint.
I was a little worried about the pipe that's travelling to the nearside headlight catching the ground/radiator/other unwanted stuff, but it seemed to fit just right into the gap between main grill and lower vent- it sits very tight so there is nothing to worry about.
As you can see I have made pipe a little longer to allow me to rest the bumper on the ground before disconnecting the piping.
Anyways, after a few days of hackery, shouting, throwing tools in the air due to frustration and many wiring diagrams later, here is how it looks like now.
(Minus the tow eye cover that my forgetful *** forgot to put back on)
Any feedback (positive or negative) welcome :)
Also, I am planning to complete a self-levelling retrofit. So far I have found the headlamp control module and axle sensor. Besides the wiring and, obviously, coding, what else is required to complete the setup?
Many thanks!
Reactions: dk1234 and maxpayne
Many thanks!
You might want to drop @Ash187 a pm as he is the retrofitter or @t8ups as he is the lights guy
2x level sensors, auto levelling control unit, wiring and coding.
Thanks, @Ash187.
Are the front and rear axle sensors same or are they two different part no's?
Also, how does the control unit connect to the ECU, via a dedicated wiring harness or a shared one (meaning I'll need to swap out a chunk of wiring from the donor car into mine)?
Asking because I will be purchasing the parts from an online breaker and I'll need to know what to buy exactly :)
