Hey All.
So woke up this morning ready to head to work, started the car and the engine light stayed on!? Drove the car to work and all seemed OK but still showing engine light.
Ran a VCDS Scan and came back with the following:
2 Faults Found:
5182 - Particulate Trap Bank 1
P2002 00 [096] - Efficiency Below Threshold
Intermittent - Not Confirmed - Tested Since Memory Clear
5162 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [232] - Implausible Signal
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
So would appear something is not right with my DPF or possibly a sensor. Never had any previous issues with the DPF on this or any other car.
So options are:
1. Go for a drive and perform a regeneration while driving
2. Perform an idle regeneration following instructions from Ross-Tech
3. Take it to my garage and let them inspect the DPF and/or G450 pressure sensor
Any help/guidance is appreciated.
2 Faults Found:
So options are:
) is that this sensor senses the DPF is around 45%+ full and communicates same to the ECU which initiates an "active regen" which involves shutting down the EGR system for a short while, raising idle speed and altering the injector activity to create more "burn off" heat. There is also the 3) "service regen" to which you refer via VCDS. I suspect your problem is a "dead sensor" and not necessarily that there is a problem with the DPF - denoted by the engine management system warning light and not by the specific DPF warning light.
