Looks great Kris.
Where the did the pedal rubbers come from and are they are straight swap?
Don't your new ones fit the same way as the old ones on the brake and clutch?
Thanx mate,Loving what you’ve done with your car. And the colour really sets it off. I especially like the wing mirror covers and the silver strip on the front valance
Have you tinted your front lights? They look darker in that last front on photo
Cheers, Sean.Looking good mate, thinking of getting one of those grills on eBay. Not sure on the quality though
I've put relay with 20W 8Ohm resistor.Cheers lads I'll hunt down b5nuts thread and see what I can find. What resistors did you use @KrisKrk? Think I might have to add this to the list of things I never get around to doing!
Springs arrived today so will try them onRecently, I've replaced failing tailgate struts with slightly longer and stronger ones.
Used 500mm 690nm struts from C5 1997-2005 A6.
Tailgate opens bit higher and faster.
Have to use more force also to shut it.
Planning on to use die springs on the strut pistons to allow auto spring out boot opening from the key fob.
Need to work out all measurements first and once all sorted, will attach pictures and video
Sent from my CLT-L09 using Tapatalk
Didn't work outSprings arrived today so will try them on![]()
Sent from H P20 PRO
Due to upcoming MOT, an air horn has been relocated.Fitted few days ago an air horn and connected it temporarily instead of the main horns.
Longer horn have a blast but not as loud I was expecting. Probably would need a proper air tank and compressor system to have the same effect like lorries.
Also, quick honk is not as responsive. Kinda expected that.
Don't think I would find easily use of dedicated button for the horn fitted elsewhere.
Once you want to blast someone with that horn, you move your handstraight away to the middle of the steering wheel.
Will see how it perform on longer run
Can't you trouble for non standard horn?Why are you bothered about the air horn for the MOT? Shouldnt be an issue. My 205gti came with similar air horns from the factory.
Steve
Got the replacements today.Didn't work out
Springs tad too long and it doesn't allow boot to close, just by the latch. Ehhh
Will phone the company I got them from to get the replacement asap.
These are Medium Load springs but one manages to pop the tailgate right up so think I will down grade them to Light Load.
Will check the spring out force shorter ones have and decide then.
Tbc ...
Sent from H P20 PRO
Thanx, Sean.That's brilliant mate, this was on my to do list when I had a mondeo. Wish I could do this with my saloon.
