How to: Blank Dash Button mod for garage remote control
SDB
This is a bit of a niche mod but someone out there may find it useful.
Making use of the spare Dash Buttons to activate an electric garage door or gate remote control is done in two stages; firstly convert the static buttons on your dash switch unit into moving buttons and secondly prepare the remote fob.
[where possible, use plastic tools when prising things apart otherwise you’ll damage or bruise the plastic]
First Stage:
Buy a second hand dash switch unit (e.g. ebay for between £15 - £20).
  1. Take the second hand unit apart in this order;
3a
  • Remove the three torx screws (you’ll need a T8 torx bit) that holds down the large flat plastic moulding covering the pcb.
  • Remove the five torx screws securing the pcb and lift it out along with the rubber strip and put them safely to one side.
  • Remove the torx screws at the side of the unit (one each side) that hold the front mouldings in place.
  • Remove the chrome trim by carefully prising the clips over the black plastic tabs.
  • From underneath carefully prise off each of the switch covers (be careful – you will break some of the retaining tabs, fortunately the covers will go back on ok with one tab in tact).
  • The white moulding that was behind the ‘Passenger Airbag’ cover must be removed next.
3b
  • Carefully squeeze together the two legs of the moulding at the same time pushing the moulding outwards. This plastic is very brittle and one of the legs will break if you squeeze too hard.
  • Once this is out, unclip the button frame (the moulding with the ‘windows’ for the buttons) from the body part by lifting the clips over the tabs of the body part.
  • The switch moulding plastic part (black is the moving one and white is the static one) is much more resilient, they are removed by squeezing both sides fully in (as shown in the picture) to free the sides from the pivot pins at either side and at the same time push the moulding outwards. Use two metal flat bladed screwdrivers (or long nose pliers) as it takes a fair amount of force to push the legs in. You only need the black switch mouldings, no need to remove the white parts from the sacrificial unit.
4b
2. Take your unit out of the car using radio removal keys.
1b
3. Strip it apart in the same way as above.
4. This time you need to remove the white static switch mouldings. Replace them with the black moving ones you removed from the other unit. They just push in and click into place.
5. Reassemble all the parts and turn your attention to the pcb’s
7b
6. You need to ‘desolder’ the surface mounted switches from the second hand unit and solder them onto the blank spaces on yours (keep to the same orientation as the existing ones on the board).
7. I didn’t fit any additional led’s as I didn’t want any indication that the buttons did anything, but now is the time to do this if you want to.
8b
8. Once you have all the surface mount switches on the pcb, assemble it back into the unit along with the rubber strip that acts as the ‘spring’ for the buttons. Fix the pcb in place with the five torx screws.
9b
9. Put the cover back on and secure it with three torx screws.
10. Don’t forget the two torx screws for the side holes that hold the body to the ‘window’ frame.
In the car you will have seen the 20 pin connector from when the unit was removed.
14c
For UK cars the button switch pin slots are;
1 = Drive Select
2 = Stop/Start
3 = Park Assist or Spare (right side of Stop/Start)
4 = Parking Sensors or Spare (left side of Hazard)
6 = Hazard
7 = Traction Control
9 = Spare (right side of Hazard)
11 = Common earth to all switches
17 = MMI Screen Up/Down
You’ll need a repair wire for these new connections (I had a spare loom from a footwell light install with the correct connectors on that I was able to use).
Plug the wire(s) into the empty slot(s) you want to use and run the cables behind the dash towards the fuse box, this is easier to do if the glove box is removed.
Second Stage:
1.
Take your remote control apart and identify how it switches, you’ll see mine had a small surface mounted switch which I removed. This was bridged with copper wire to complete the circuit.
10b
11b
2.
Solder two tails to the battery terminals. Put the covers back on to protect the pcb, after making a hole for the cables to escape.
12b
3.
I connected these two cables into a small multi-plug connector (from Maplin). The mating half of the connector was wired up with the lead from the dash button and an ignition switched live from the fuse box.
4.
So once the two halves are pushed together the live feed goes to the positive terminal of the remote and the dash button cable goes to the negative terminal of the remote. The dash button completes the circuit when depressed, but only when the ignition is on.
5.
Tidy the cables up and hide the remote control behind the dash or glove box or end panel of the dashboard.
6.
Enjoy the new addition to the dash buttons.
Hope this is useful to someone.
Reactions: Badger-a-s, toooldforboyracing, Np1389 and 19 others
That's really cool! I like that :) I have no use for it that I can think of... but it's cool still :D
Wow... nice mod. Lots of effort.
I was looking at this kinda thing, but ended up buying a GoGoGate and telling android auto to 'Open Garage Door' etc (via IFTTT).
Reactions: azibux1
First Stage:
1 = Drive Select
2 = Stop/Start
6 = Hazard
Second Stage:
1.
2.
3.
4.
5.
6.
@SDB - Great thread buddy
Thanks for sharing
Really nice mod and good write up.
@Bristle Hound . is this not worthy of adding to the sticky threads - useful mods section?
Thx
Jungle
@jungle650 - Added to A3/S3 8V FAQ's How To's
http://www.audi-sport.net/xf/thread...-on-the-8v-chassis.198794/page-2#post-2574035
Reactions: jungle650
Glad you think it's worth making a sticky.
I've leant a lot from this forum, so happy to put a bit back.
Cheers.
Reactions: paul wev
Excellent mod and write up.
I did a similar mod on my Golf R with one of the switches by the parking switch. I even got the blank laser-etched with a garage door logo! But I'm now looking at going back to an A3 and was wondering what the options were for the garage door opener. I'm glad someone has done all the donkey work already. Thanks.
http://www.vwroc.com/forums/topic/1...nhancing-mods-have-you-done-to-your-r/?page=5
I really need have a good clear out of the junk in the garage and then change the garage door; just for this....
Reactions: paul wev
@SDB Do you know if the missing LEDs provide back lighting for the relevant switch or an "on" colour?
The LEDs on the side that contain the surface mount switches illuminate red for the backlight to the individual switches (but only if they are engraved to show the white colouring through the black - great attention to detail on your Golf R by the way ).
On the opposite side of the pcb there are more LED's and these illuminate yellow (e.g. for parking sensor light or stop/start) . These are for the illuminated window above the buttons. Bear in mind these are only momentary switches, so on when pressed / off when released, so the yellow light would only be lit when the button is pressed.
Reactions: GeoffT
I used up some of my blank switches too. The one right to the ADS button, I'm now using as my Bilstein Ride Control switch to switch from sport and comfort mode.
The one next to that I used as a toggle to turn on the rear backup camera at any time (I have aftermarket one).
I'm still trying to figure out a good solution for printing out graphics, something like a sticker, to match. I'm glad the switches are as simple as they are, at first, thought they were LINBus controlled, which I'm still trying to figure out to use the steering wheel buttons for other multi-function controls.
Sent from my Pixel 2 XL using Tapatalk
@rcnacura
I used these guys to laser etch a blank button with my garage door logo. They were very helpful and it gives a really professional result with whatever design you want and it can be backlit too. They are in Devon only about 25 miles from me so I drove there myself and they did mine there and then, but can do it by post if you aren't nearby. I would definitely use them again.
www.laserncreations.co.uk
Reactions: Nagasaki, paul wev and rcnacura
@rcnacura
Thank you, I'll see if they can help me out. Mind posting a picture if you have a second?
If you follow the link I posted above to the VWROC forum there should be pics on there. If that doesn't work let me know and I'll dig my originals out.
They were easier to find than I thought so here they are
20151215 112714 20151215 174956
Reactions: S3Gus, paul wev and rcnacura
This is a nice mod!
I don't have a garage, but trying to think of things I could use a blank panel button for now (though to be honest, not sure I have any blank ones...)
@rcnacura
Hey mate, how much did the laser etching cost you?
Sent from my SM-G950F using Tapatalk
I can't remember exactly but I think it was only about £15. I think that might have been a special rate as the guy there was quite interested in what I was doing and we got through a few of my blank buttons before he got to the perfect settings for his machine. For the time he spent on it, it was a bargain, but I guess now he has the settings it would be quicker and therefore still a reasonable price.
So it makes a blank plastic button 'see through' as such so the backlight from the car shines through? I'm getting an exhaust one done that's all so I want it to glow red like the others on my dash
Yes exactly that. The buttons are effectively a white moulding with black paint on them. The laser etching removes the paint in the area of the logo so it looks white in daylight and will be backlit by any light behind it at night.
Genius! I'll get in touch and see if they'll give me a price
I'm starting this project now as something constructive to do while I wait for delivery of my car. I've got 2 switch panels from eBay and my plan is to morph them into one with all switches active. One of the new switches will be for my garage door, but I thought I might as well do both spares while I'm at it just in case. Doing it that way I don't have to modify the one that comes with the car, just swap it out and add the wires to the connector. Easier to switch back come trade in time as well.
So far so good and I've got both of the units apart OK thanks to the excellent guide above, but one of the trim pieces that sits behind and between the switch buttons is matt black and the other is gloss black. I presume they are from different spec cars, but which type will come with my BE Sportback? I much prefer the gloss black so would probably go with that anyway but I hadn't realised or spotted in any pics that there were different versions or seen any options in the configurator.
The more I investigate the more complicated this project gets! Firstly I've discovered that if you want to backlight the spare buttons, which I do, it is not simply a case of adding the LEDs from the donor board, the "drop down" resistors that feed the spare LED positions are not fitted either, so I need to "harvest" them from the donor board and solder them to the board. As they are about 3mm by 1mm, working with them is what even a Swiss watchmaker would call "a bit fiddly".
Secondly, and more crucially, I've only just discovered that the A3 backlighting colour has changed from red to white in the last year or so. Was that part of the facelift? Both of the boards I have bought are older red backlit ones. So now I have just had to order some white LEDs from RS. Whoever said why not just use a cigarette lighter remote may well have had a point, but I will not let it beat me and I do have over 3 months to get it done.
Reactions: Tej13, paul wev and Dunedin
Finally I've got it working with the laser etched buttons and backlights in white.
[photo=medium]9183[/photo]
[photo=medium]9184[/photo]
Reactions: S3Gus, paul wev, oli356 and 1 other person
Excellent result.
I went for the stealth mode so as not to draw attention, but after seeing the quality of the etching I'm tempted to get mine done now.
I'm 99% happy with it. The one percent is that the white LEDs I got from RS for the blank positions seem to be a slightly warmer white than the OEM ones and the diference is just about visible if you look really hard.
I thought I would update this with details of how to get the switch backlights working if anyone is interested. I used 1k ohm resistors and the brightness seems to match the OEM ones very well.
Worth noting is that the button blanks are actually a slightly different shape depending on if they are on the left (position 3) or right (position 6) of the hazard switch - they have a very slight curve on them one way or the other. They will fit and work in either position but don't sit 100% inline their neighbours if they are the wrong hand. Unfortunately I only realised this after I had some laser etched! Together with not realising that the facelift versions are backlit white instead of red, means I do now have quite a few spare parts! I probably have enough to make up a complete assembly with a garage door logo switch in position 3 and a switching blank in position 6, all backlit in red. If anyone would be interested in buying that let me know and I will build it up. I have a choice of matt black or gloss black (as in my pic in my previous post) dividing grids . I never did find out for sure but the gloss black ones were advertised as being from an RS3 so they presumably will add quite a bit of horsepower as well! I don't know exactly how much to charge for the completed assembly but the basic switch blocks have been costing me around £30 and I've seen them as high as £50, so with the work and the laser etching of the button, I reckon it's got to be worth £60 hasn't it?
LED and Switch Positions
Position 3 LED resistor
Position 6 LED resistor
Reactions: paul wev
Hi,
Fantastic write up.
I am about to modify a spare one of these I have bought to operate my after market front parking sensors, basically to turn them on and off using the switch.
Do you know if all the micro switches are push to make and are some of them push to break (i.e on and off)
Hi Geoff, just done my soldering and want to check the led. Should it light up before I do anything else or do I need to connect it to the switched garage opener or whatever I'm connecting it to
