Ok I have my sparco steering wheel at the ready with boss kit and quick release. Had a quick look today behind steering wheel airbag what I am gonna be facing and doesn't look all that bad.
Right obviously can see airbag connector I got a 2.2ohm 0.6w resistor for this so hoping I can just put the legs straight into connector put some electrical tape over it and tape rest of connector together out of way. As you can see the 2 spade connectors a brown wire and a black wire which I gather is for horn brown is positive and black is earth so these go straight to my horn button. At the back of the airbag itself I presume the black wire is just an earth for the airbag?
Does it matter which way round I put resistor into airbag connection one wire is blue and other is brown.
Thank you
Forgot what size is the hex screw as all I had was a T50 and this was too small. I was actually expecting a nut that I just remove with a 17mm socket but not to be.
Thank you
