Audi A7 rear door handle removal
stephen s
Hopefully someone an help urgently. I need to remove the drivers side rear door handle to get it painted after a scratch in it. Can anyone advise on this as the paint shop is booked to do this. Thanks in advance!
If it's like any other model then remove the plastic cap on the end and the handle will come out.
Do a google, plenty of info out there, the 4G A6 should be the same if not similar.
Ignoring the commentary, this is probably as good a demo as you will get.
Sorry it doesn't work. There is a rubber plug in the door that you remove then there's a t20 torx screw there that you back out but still nothing. Amazed that someone hasn't done this before on the web.
