EGR Delete Why?
Ianski68
West London
so as a total noob, i see a lot of people saying that the EGR delete is the best basic mod you can do! so three Questions:
1/ WHY?
2/ i have a A4 2.0TDi 140 BPW engine. i am not a boy racer just love cruising the country roads with the top down, would i benefit from doing this?
3/ on my engine what would be involved?
i am sure this is a well versed subject....
1. It cloggs up.
2. Yes.
3. EGR delete kit, maybe mapping out too unless you use a small pipe to trick the ECU.
1. It cloggs up.
2. Yes.
a dlete kit for my engine, where would i look for one? obviously i imagine that there are many versions. i know on my engine it slides into the top of a manifold and has a rotating valve where as others sits between the manifold and shudder valve etc....
Egr
so i have had my car 2 years, never cleaned the EGR. if i clean it does it have a gasket that will need replacing or does it have a re usable type one (copper etc)
i did say i was a total noooooooooooob lol
Following this thread because I am interested in doing this myself.
This is a VW but has the same engine as mine. EGR looks simple to clean, but still would like to know if a delete would be better and info on parts etc..
Well if the man in the video can do it I can too.
So I did. This is what I found.
IMG 8737
I was so pleased after I had cleaned and polished it I forgot to take o photo! Derrrrr
Reactions: J0N and tony mc
Removing the EGR valve keeps the whole intake system cleaner once removed. No downside to remove it.
May cause the EML to come on unless mapped out.
First thing to go on any of my diesel or petrol engines
Reactions: Pie-eyedpiper
So will there be a specific kit for my engine.? what will it comprise of?
thanks.....
You've just cleaned it , no need for a full delete kit.
Stainless steel 1.5 mm slip in blank and remap .
okay that,s simple enough to do. i imagine someone does a made to fit plate.
since i cleaned it the car does seem smoother.
It'll be even smoother , more powerful and pull from lower down when blanked and remapped .
Engine code ?
Mines done 88k gonna plan this mod for next weekend
My engine code is BRE which blanking plate should I go for and is it easy to fit?
Darkside do a full kit if you want to fully remove the whole ERG unit around £90 get rid of the EGR cooler too makes working on the engine a lot easier
Ian I take it this is what you EGR looks like when it's on the car?
If so it looks like you need this type of plate to delete it
If it is the correct kit then the cheapest I can find is roughly £60 all in HERE
I hope that someone can confirm that your BPW engine is the same set up as the ones in the listing BGW & BHW.
I know that on my BRD it's a different set up but I'm sure that you can turn the EGR off or to the point it's basically off via VCDS like you can on mine.
That's the one. I emailed Dark side but they gave me the wrong info regarding the kit. But you have nailed it.
Will it require remapping and VCDS to finish it off? Huge thanks
If you can get access to VCDS you can edit the settings of the EGR Ian. Then in theory that should suffice to totally disable it to it ever so slightly on the verge of being 100% totally disabled.
I was going to just use VCDS on mine but I ended up getting a remap and got it disabled that way and then not much later went for the DPF delete also as I have the 170.
Dark side developments say on their site not to blank the egr valve if you still have an active dpf ?
Reactions: RS4B5
I don't know why as all it does is let hot air into the engine when it's idling and as soon as you raise the revs with driving it closes.
I never had any problems with my DPF apart from it running better.
Egr is a prerequisite of dpf regeneration it helps regulate the pressure and temperature during regeneration , without , the dpf could block .
Reactions: RS4B5
As it's only the 140 it shouldn't have.....but it came to light not so long back that some did have an optional upgrade to a DPF, or should that be downgrade?
Reactions: RS4B5
So if it has a dpf filter then I need to remove that aswell!
The list is growing.
Thanks everyone.
Basically anything that inhibits full oxygenated combustion and inhibits exhaust gas flow reduces power and mpg .
So you want nothing but cool air for induction and a free flowing exhaust .
The downside is diesel particulate matter and NOx emissions .
Thanks everyone.
I read somewhere on the Vag forum that audi only started putting DPFs on their diesels in 2007, apparently no PD140 B7 engines have a DPF, only the 170s.
They came as an optional free upgrade on the 140's......I only found out when another member on here put me right as I was only aware of them on them on the 170 variant of the 2 litre oil burners.
images
Turn the key and find out .
I don't seem to have this warning light on my instruments when I turn the ignition on....did I escape??
2008 2.0 tdi 170.
I don't have that image on my clocks either and never had but I definitely had one on it at one point....I think mine fell off somehow hehehe.
A 2008 170 you will have one on it.
Reactions: J0N
Sorry for double post, blanked easily, but now the turbo sometimes doesn't spin up, it's like the car is in limp mode but then sometimes the turbo works fine and I get some really nice acceleration.
Do I need to remap the egr out to fix this?
Hi guys
I've come across this thread as I previously had a a4 b7 and before I started to really learn about cars I had to get the EGR valve replaced so had a garage do it.
I now have a b8 170 tdi and am looking into possibly deleting it. I was wondering if anyone had any advice if it is still worth doing. I noticed that above a remap has been mentioned. I currently don't have the car mapped, however I am running a dtuk tuning box and pedal box.
My engine code is CAHA.
