Unknown Broken pipe off induction piper after maf Car stalls sometimes
Demos
Hey there I am having an issue with my car as sometimes when I start it it stalls straight away, I had an issue with vacuum leak but solved it by adding the missing seal between the master cylinder and the booster.
I have now identified that there is a pipe which I don't know what it is from or why but I am guessing it could be related the the problem I am facing.
I am attaching the pictures of where this pipe used to come off the induction pipe but now its closed with a bolt and where it attached to which is still torn.
Any help identifying the part is appreciated.
looks like someone's snapped a barb of the n75 valve and subsequently blocked the surplus hole in the induction pipe
Reactions: Demos
Thank you very much Alex. I will order a new valve and see if that solves the issue.
Hey Alex, I ordered the N75 valve and replaced it, the car is running smoothly at the moment. Thank you very much it solved the issue.
Reactions: Alex C
