  2. Dismiss Notice
323mm Brembo GTjr - Which discs?
MintyS3 Apr 17, 2012
  1. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    9
    Hi guys,
    Needing some new discs for the S3 with a brembo GTjr kit (leon setup). What would you recommend?
    The standard grooved brembo discs have definitely seen better days do want to maybe move away from them. Got a nice set of ferodo baggins ds2500 pads waiting to go on too.
    Ive had a standard set of discs priced at £280 which seems quite alot. Black Diamond grooved are about £330 and EBC standard are about £140....Have had ebcs on the back of a previous car which was fine as theres hardly any braking force there but what about front?
  2. Avatar
    snack-media
    Advertisement
  3. aragorn
    18,716
    902
    Buy the cheapest ones you can find.
  4. jcs356
    jcs356 Brum brum
    2,740
    80
    I've just put a set of these on following a recommendation of a friend on SeatCupra.net. I've not really put them to the test yet (mostly motorway miles thus far). They seem to be some sort of a German make but no idea where they are actually made. £179.50 + £12.50 delivery.
    Front Leon Cupra R Grooved Godspeed Discs - Godspeed Brakes
    I had a similar dilemma to you - I run Black Diamond on the Cordoba but didn't fancy £300 plus, and have had bad experiences with EBC Ultimax discs.
  5. aragorn
    18,716
    902
    IMO disks are disks.
    Any bad experiences are typically down to overheating them or not bedding them in properly and as a result getting pad deposits.
    I've never used anything other than cheap standard motorfactors disks, and i've never had any problems.
  6. MintyS3
    1,580
    9
    Well I got the standard discs price down to £220 so £60 off aint bad. 12month warrenty on them too so will do fine.
    Ive warped black diamond discs in the past too...
  7. Jimgrim77
    Jimgrim77 Member
    956
    21
    Aragorn is spot on. Makes no difference aside from aesthetics.
    I have that set up and bought pagid discs, I think, from eurocarparts. Still set me back about £200 though. Not cheap due to size.
  8. aragorn
    18,716
    902
    I think its more rarity than size.
    B5 S4 disks are 320x30mm and they're nowhere near £200! Heck even the 345x30 disks from the B6 S4 are only about £50 a corner!
  9. Jimgrim77
    Jimgrim77 Member
    956
    21
    agreed again.
    323mm are a nightmare to find but...that's the size they recommended on those units for good or bad. i wanted to maintain the stadard lcr sizes.
  10. moredoor
    moredoor Member
    160
    I've just got myself a set of EBC discs from GSF at £140, From the point of brake pedal feel at road temps then most discs all feel the same and offer very little real gains. I find drilled discs crack around the drilled holes and grooved ones made too much noise for daily use.
  11. jojo
    29,072
    3,799
    I'm using OEM LCR solid discs, they are around £200+vat. I would have preferred drilled discs, but Brembo want £350+vat, and they are notorious for warping.
  12. Avatar
    snack-media
    Advertisement
  13. MintyS3
    1,580
    9
    Well the brembo discs supplied with my kit never warped and I baked them at the ring. Not worth the price though.
  14. badger5
    10,206
    2,374
    ebc plains £120+vat/pair
    eliptically grooved versions £179+vat
