Park Assist (PLA) Coding
asmetana
Northern California
For those of you with Park Assist aka PLA (this is the kit that does the semi-automatic parking and adds sensors 5 & 6 to the very edges of the bumpers), would any of you be willing to share your coding and adaptations, even if stock? Specifically I'm looking for modules 10, 17, and 44. If there are other tips on it, please do share.
I've recently retrofitted my US-spec 2015 A3 sedan (PFL) with the kit and I'm not quite ready to trust it to do the self-parking thing with my own coding, though I certainly do appreciate having the extra sensors to help prevent me from curbing a wheel!
Why don't you trust it? It does the steering for you but you are still in control of the movement so there's not really any risk!
To be fair it's the one feature that is practically useless unless you really can't reverse park for toffee. In which case park assist plus might make a better hash of it. If it had access to VCDS I'd share the coding but it might be worth considering that we drive on the "wrong" side of the road.
It's a convenience feature. I can park perfectly well, but it's nice to have, and not all that expensive once you've got all the sensors back and front anyway. It can handle either side of the road though if you use the indicators (though it defaults to left if you don't).
I forget where the coding was but another module tells it the default for which side of the road you drive on so I'd still appreciate any coding/adaptations you'd be willing to share.
I really installed it for the extra sensors, the self parking is an added bonus. I just don't want any more wheel rash. I'd like for the self parking to work well but it sounds inconsistent anyway. I could use it on my full-sized pickup truck, no sensors on the front and parallel parking isn't quick.
This morning after dropping the kids off at school I had cars parallel parked in front and behind me so I let it take me out. It worked fine, though a little disconcerting initially.
I use it all the time. In the facelifts it constantly monitors for available parks so you don't even have to activate it to search!
Sent from my Pixel using Tapatalk
Asmetana, just dropped you a conversation, I´ve just bought the PLA+ Sensors kit +OPS from China (aliexpress) in order to upgrade an 1.8T Quattro in Argentina. Would you share any circuits/tips/do´s & dont´s for me? an dropbox link or something similar with pictures/info would be great buddy !!! thanks again...
Hello,
I bought the same kit PLA 2.0 for a 2015 Audi A3 8v Sportbag and I need a tutorial to do the retrofit. Can you please help with any information you may have. Also the necessary codding that must be done.
Thank you!
@martinlop, just replied to your conversation.
Hi,
Can you please help me with the same information that you sent to the user 'martinlop'. I bought a kit PLA 2.0 for Audi A3 8V and tomorrow I want to do the retrofit and I need any information.
Thank you!
hi y´all, sorry to bother you with such a stupid question, but Ive spent several hours doing reverse engineering, reading forums for weeks, and working like a horse, now this frustrates me.
attached an auto-scan. long story short:
Im retrofitting my a3 8v with a new 5Q0 919 298H and after everything is installed, the m...fkr tells me he wont accept any coding: 31-error, coding rejected (with VCDS last version, original cable HEX2)
looks like its a brand new module, (not used) but i have read everywhere the park assist module/gateway doesnt come with CP.... so, now Im clueless how to code it.
for some reason, it has taken the adaptations wheel circ. I´ve sent thru VCDS, but doesnt like the long coding..
any ideas for my next step? puting some fuel below the car, and a match will probably be the best one!
Code:
Sunday,08,October,2017,18:22:48:08873
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WAUBCJ8V3G1103064   License Plate: AB132
Mileage: 8174km-5079mi   Repair Order: DOMINGO
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 52 55 5F BB BC
VIN: WAUBCJ8V3G1103064   Mileage: 8174km-5079miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJSB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 H    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 0A9D00322406010B2000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM18TFS0208V0906264H 001007
   ROD: EV_ECM18TFS0208V0906264H_VW37.rod
   VCID: 41DC4C40810BE09F144-8014
No fault code found.
Readiness: 0010 0001
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 012 F    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4930
   Revision: 06253104    Serial number: TFK01604011950
   Coding: 0014
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 196CC420491B985FBC4-804C
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 61036000005855
   Coding: 13F16AA234202A6F0377070641C729C8562C54C0E08294F5004150348608
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 79ACE4A0A95B785F1C4-802C
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-043.clb
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000912514
   Coding: 03000004110000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
   ROD: EV_AirCondiFrontVaAU37X.rod
   VCID: 323E138C34AD4B079DE-8066
   Relative humidity sensor in fresh air intake duct:
   Subsystem 1 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: 24F9032800PAG0MUFU01
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061610903953
   Coding: 04041A42C24122FD03804004B10807080000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 015001
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 04528554DE9935B77F2-8050
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 160408  043 0585
   Serial number:         160416080445
   Coding: 0A47F7
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0004
   Serial number: 61660501
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
   Component: E1 - LDS MQB  H05 0032
   Serial number: 25 01 2016  00001125
   Sensor For Anti Theft Alarm System:
   Subsystem 4 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1602637Q8
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065608331
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 H    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0053
   Revision: --------    Serial number: 39431427200492
   Coding: 0000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 003020
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 44D245549E19F5B73F2-8010
3 Faults Found:
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 82
                    Mileage: 8163 km
                    Date: 2017.10.08
                    Time: 16:58:54
13636352 - Control module not coded
          U1013 00 [009] - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 82
                    Mileage: 8163 km
                    Date: 2017.10.08
                    Time: 13:38:44
13697024 - Control Module
          U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 82
                    Mileage: 8163 km
                    Date: 2017.10.08
                    Time: 13:38:45
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    015 0388
   Serial number: 003MMR1NJNLW
   Coding: 98CCC000000000005C540000004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 005A8944CA8129975BA-8054
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 480 000 804 16
   Component: SideSensor_Df  001 0887
   Serial number: 3576700000078A916A1.
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 000 804 16
   Component: SideSensor_Pf  001 0887
   Serial number: 3586700000003A916A1Q
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 480 400 904 16
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502C11FA3425C2DG
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 480 400 904 16
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502B120414E3515V
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 604 16
   Component: FrontSensor_D  001 6149
   Serial number: 3556502C720414F3902%
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 8V0 953 521 EM    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 16041604221228
   Coding: 8018
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_020_AU37.rod
   VCID: 094C9460F9BB68DF0C4-805C
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 871 R    HW: 8V0 920 871 R
   Component: KOMBI         H03 6423
   Coding: 078D18082B9000080500A8001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009051
   ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
   VCID: 4BC06E68B3473ACFFE8-801E
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 15041610801377
   Coding: 030100043F085A005B000248180B00000001010000000000000000000000
   ASAM Dataset: EV_GatewConti 013020
   ROD: EV_GatewConti_013_VW37.rod
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 8U0 951 528 B    HW: 8U0 951 528 B
   Component: E221 - MFL  H02 0014
   Serial number: 06 04 2016  C0018702
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704901603232224
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 H    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7083
   Serial number: HA1-00019.03.16
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
   VCID: 4ACE6B6CBC3D23C7C5E-801E
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Component: TSG FS        020 0041
   Serial number: 040316EC316159
   Coding: 001C0A204100040000001002
   ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0303
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB.rod
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Component: TSG BFS       020 0041
   Serial number: 290216EBJ08118
   Coding: 001C02204D00040000001002
   ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
   VCID: 40DA49448A01E9971BA-8014
Address 55: Headlight Range (J431)       Labels:| 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 01AA000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75B4E89085431C3F78C-8020
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 8V0 035 840 C    HW: 8V0 035 840 B
   Component: MU-S--ER      042 0461
   Serial number: A3E01204160010
   Coding: 01730100FF0A000021220001001A00002F0001040100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 35342890C5C35C3FB8C-8060
   Display unit 1 for multimedia system:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9GY30GM3Q
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: ALJAL116021600030034
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0041
   Serial number: 240316ECN2439C
   Coding: 000C02204000040000001002
   ASAM Dataset: EV_DCURearDriveMINKLO 006003
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   VCID: 43D046489B17F28F068-8016
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 240316ECN20631
   ASAM Dataset: EV_DCURearPasseMINKLO 006003
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
End----------(Elapsed Time: 01:32, VBatt start/end: 12.6V/12.6V)-----------
these are actually the errors that bothers me most:
U1013 00 [009] - -
follow up from last weekend.
after removal of both connectors T26, and T18, and connecting them back in,
ave sent a Long Coding type: 0031xxxxxx and had worked.
but now, im struggling because if I drive my car, and reduce speed, after speed is reduced below 15 km/h, system starts to beep (currently have disconnected the front sensors, and I will punch the bumper once everything works from the outside.
After beeping I have 2 choices, either hit the button of park sensors, or accelerate further (sometimes the second is not possible!)
Hello, i have fitted my A3 8v 2014 sportback with the same kit, comming to aliexpres and new i need to do coding i have ths errors
U1013 00 [009] - -
Somone can help my. Please
disable the automatic front sensors and check your adaptions.
I can't do anny adaptation to this modul. I gheve a 31 error mesage
Use security access 71679 before doing coding and adaptions. Is the module parametrised?
A3 8V Facelift Limousine
Saturday,19,January,2019,10:50:35:64015
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.0.4 HEX-V2 CB: 0.4437.4
Data version: 20181017 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ8V1EA189564 License Plate: WW
Mileage: 124562km-77399mi Repair Order:
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F 6C A5 BB BC
VIN: WAUZZZ8V1EA189564 Mileage: 124562km-77399miles
13-Auto Dist. Reg -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CRKB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FD HW: 04L 907 309 E
Component: R4 1,6L EDC H22 6544
Revision: 86H22---
Coding: 02190012034411092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI01104L906021FD 002004
ROD: EV_ECM16TDI01104L906021FD.rod
VCID: 6C81C6C976045797523-8038
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 6105400000059A
Coding: 12F162A224280A75017C060641C72548462450806082A4F2F441F0080608
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 7BA3F595036AC02FCB9-802E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000306869
Coding: 03000104002000001000000000001000
VCID: 33331DB56BBAC86F539-8066
Component: AQ_Hum_Sensor H03 0003
Serial number: A6988527000000000001
Part No SW: 5Q0 937 084 BR HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0138
Serial number: 01011415301252
Coding: 04040946C24102FD43844004001407080000000000000000000000000000
Shop #: WSC 06745 128 28888
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 094F9F5D59B6E2BFC95-805C
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140412 042 0580
Serial number: 140416135254
Coding: 0A47F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22535822
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 Q HW: 8V0 941 531 Q
Serial number: 30 10 2013 00000995
Part No SW: 5Q0 919 298 D HW: 5Q0 919 298
Component: PARKHILFE PLA H11 0042
Revision: -------- Serial number: 61131402901978
Coding: 0031161041
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 40D942792A0C63F7DEB-8014
2 Faults Found:
[Steuerger䴠fr Bremse - ESP_02.ESP_Status_ESP_PLA - PLA-Codierung in Bremse prfen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 248
Mileage: 124562 km
Date: 2019.01.18
Time: 18:34:32
13637426 - Databus
U1123 00 [008] - Received Error Message
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 34
Mileage: 124562 km
Date: 2019.01.18
Time: 18:59:55
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 H HW: 5Q0 907 567 H
Component: ACC3 H10 0096
Serial number: 16041476110542
Coding: 00200501FE0309
ASAM Dataset: EV_ACCBoschMQB 001023
ROD: EV_ACCBoschMQB_AU37.rod
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R06D5XP
Coding: 98CCC0000C0000005C540000004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4BC36555134AB0AF3B9-801E
Subsystem 1 - Part No SW: ----------- HW: 480 001 504 14
Serial number: 357670000006D2993F0%
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 480 001 504 14
Serial number: 35867000000082993F0W
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 480 401 604 14
Serial number: 3516502AF1529DF1A10I
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 401 604 14
Serial number: 3526502AF1529DF2504I
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 480 401 103 14
Serial number: 35565029B14476B1B17D
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 408 15
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A71CF1D33126D
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 402 15
Component: PedP_Sensor_P 001 6149
Serial number: 2296502A7198E15340EG
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 402 408 15
Component: PedP_Sensor_C 001 6149
Serial number: 2306502A51CF1D32F2AL
Coding: 2D2D2D
Part No SW: 8V0 953 521 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 16041408490098
Coding: EC08
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 7F5B01851772DC0FE71-802A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 870 K HW: 8V0 920 870 K
Component: KOMBI H03 2220
Coding: 04AD0A00669000080382FE00100100
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 43D34D753B1A78EFC39-8016
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001761218
Coding: 030100040B0876005B000258080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3FDB418557F21C0FA71-806A
Alternator:
Subsystem 2 - Part No SW: 81A 951 523 A HW: 81A 951 523 A
Component: J453 MFL H04 0003
Serial number: 20170710213940 22742
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 3046833103
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 18041404080212
Coding: 001C0E205C00040000001003
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 1302
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DF477D21066AFFD15-8014
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 22041403110367
Coding: 001C06205E00040000001003
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 864 B HW: 8V0 035 864 B
Component: MU-S-N-ER 040 0420
Serial number: A3F01604142915
Coding: 01730301FF00000021110001000A00002F0004440100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3A2D30914CD0392790F-806E
Component: DU Std H49 0013
Serial number: AUZ8Z9EY302ULB
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000024021400010323
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 HW: 5Q0 907 441
Component: MQB RVC Mid H06 0130
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE_AU37.rod
VCID: 6FBBD1C54712AC8F771-803A
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H05 0052
Serial number: 10000065146
Coding: 0100010000010304000000000100000100
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
VCID: 3B23359543EA002F8B9-806E
Part No SW: 5Q0 959 395 B HW: 5Q0 959 395 B
Serial number: 12041404080068
Coding: 000C06204000040000001002
ROD: EV_DCURearDriveMAXCONT.rod
Component: TSG HBFS 020 0025
Serial number: 12041401100073
ROD: EV_DCURearPasseMAXCONT.rod
End----------(Elapsed Time: 01:17, VBatt start/end: 14.0V/14.0V)-----------
Hello, I need some help with abs coding
I have found the security accès ( 20103)
But I don't know wat bit changé for my PLA work finally
Thanks a lot
Hi all i have the same problem
Bought a kit from alie express pla 2.0
I need the right coding can someone send me how to code.
And a diagram of the pla switch the pla button from me is the whole time light up
my car is audi a3 prefacelift 2014
hi i just bought the kit do you have the coding and installation manual for share
Thank you very much
i still have one problem the pla button indicator light is always on .
and i can see the parking display in the fis but when i drive by parking spots is seems not scanning for the parking spot
here is the full scan
Monday,25,May,2020,10:23:32:00009
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ8V8FA065857 License Plate:
Mileage: 165233km-102671mi Repair Order:
Scan: 01 02 03 08 09 10 15 16 17 19 37 42 44 47 52 55 5F 69 6C BB
BC
VIN: WAUZZZ8V8FA065857 Mileage: 165233km-102671miles
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 0100
47-Sound System -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Not registered 0011
Address 01: Engine (J623-CPWA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 N HW: 04E 907 309 E
Component: 1.4l TSI CNG X13 7572
Revision: WIX13---
Coding: 02250032242401082000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM14CSI01104E906016N 001006
ROD: EV_ECM14CSI_VW37.rod
VCID: 2D51BCB37C11372702-8078
CAN Converter 01:
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 047 D HW: 0AM 927 769 K
Component: GSG DQ200-MQB H44 5222
Revision: 00044014 Serial number: CU501808026499
Coding: 0014
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW31.rod
VCID: 3C7781F7B76BAEAF85-8068
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62644000001938
Coding: 12F16AA224261271017F060541CA2548562448806082A4F20221502A8608
ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
VCID: 4581E413C4A1EF67EA-8010
Revision: 20026000 Serial number: 00000000443967
Coding: 03000004000000011000000000001100
VCID: 326BAFCF652F68DF5F-8066
Serial number: 4309CA47000000000001
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011426600448
Coding: 04061A42C24122FD43C44004001C07A80004000000000000000000000000
VCID: 000F35079B030A4F99-8054
Component: WWS370 140818 042 0580
Serial number: 140913214009
Coding: 0A47F7
Serial number: 23215456
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Serial number: 23 07 2014 00001476
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431711500435
Coding: 0031261011
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA2CAU3700000 003021
VCID: 479DEE1BFEADFD7718-8012
1 Fault Found:
1113619 - Parallel Parking Assistance Indicator Lamp
B10FE 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 21
Serial number: 003M2R08GFRY
Coding: 98CCC0000C0000005C5400CA004800000065
VCID: 4B95D22BE2C519173C-801E
Subsystem 1 - Part No SW: ----------- HW: 480 002 209 14
Serial number: 357670000009B0AC111U
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 480 002 209 14
Serial number: 35867000000E00AC111P
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 480 401 709 14
Serial number: 3516502A1176A6B421C7
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 401 709 14
Serial number: 3526502BB176A6B0C18L
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 480 402 208 14
Serial number: 3556502B316FC22132A8
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 480 400 109 14
Serial number: 2286502A517750B14392
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 480 400 109 14
Serial number: 2296502AB175A8E4D2F/
Coding: 2D2D2D
Subsystem 8 - Part No SW: ----------- HW: 480 400 109 14
Serial number: 2306502A7175A8E0A127
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Revision: -------- Serial number: 24091404401475
Coding: A418
ROD: EV_SMLSKLOMQB_010_AU37.rod
VCID: 09192823A8394B07CE-805C
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
Part No SW: 8V0 920 871 H HW: 8V0 920 871 H
Component: KOMBI H02 4291
Coding: 07BD0A082B9000080D027E041400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 4189F003D089C347D6-8014
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002496154
Coding: 030100042F0857005B000248140B00000001010000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011.rod
VCID: 428BFF0FD58FD85FCF-8016
Alternator:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Serial number: 11 09 2014 E0030874
Serial number: 6786024603
5 Faults Found:
131655 - No Communication with Towing System Control Module (J345)
U1003 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 165228 km
Date: 2020.05.24
Time: 13:23:43
Supply voltage: Terminal 30: 12.3 V
Terminal 15: OFF
131692 - No Communications with Undefined Control Module
U1126 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 165085 km
Date: 2020.05.23
Time: 22:20:42
Supply voltage: Terminal 30: 11.9 V
Terminal 15: On
131695 - Digital sound System control module
U106A 00 [009] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 165085 km
Date: 2020.05.23
Time: 22:20:42
Terminal 15: On
66304 - Databus
U1124 00 [009] - Additional Installations Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 43
Reset counter: 26
Mileage: 165085 km
Date: 2020.05.23
Time: 22:20:42
Terminal 15: On
15360512 - Component Protection
U1101 00 [009] - Active
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 21
Mileage: 165085 km
Date: 2020.05.23
Time: 22:20:42
Terminal 15: On
Address 37: Navigation
Cannot be reached
Serial number: 02091403111166
Coding: 001C8F204000040000001002
VCID: 408FF507DB83CA4FD9-8014
Coding: 8303
Address 47: Sound System
Cannot be reached
Serial number: 13091403111332
Coding: 001D87204C00040000001002
VCID: 3F8DF6FBA67DB5B7A0-806A
Coding: 018A000001000000
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75E154D3D4C13FE7BA-8020
Part No SW: 8V1 003 503 5D HW: 4M0 035 035
Component: MU-P-LND-EU 042 1326
Serial number: A270G0F7509165
Coding: 01730301FF0A000011111101000A00302F002AC5017001005E
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU37.rod
VCID: 63C51A8B6A55B157E4-8036
Data medium:
Subsystem 1 - Part No SW: V03 959 802 DF HW: -----------
Component: ECE 2019/2020 --- 0177
Serial number: --------------------
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9J1Y0ELTR
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL127081800050645
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1010
3 Faults Found:
1555 - Check Software Version Management
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 21
Mileage: 165085 km
Date: 2020.05.23
Time: 22:20:50
Voltage terminal 30: 12.2 V
Status_Software_Version_Management-module_name: MDUA201/Front
15360256 - Component Protection
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 165085 km
Date: 2020.05.23
Time: 22:20:45
0013 - Antenna Amplifier 1 for Digital Radio
B1270 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 21
Mileage: 165085 km
Date: 2020.05.23
Time: 22:20:45
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anheanger H21 0203
Serial number: 00006789857544
Coding: 0100000202000000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 3B7582EBB265A9978C-806E
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H18 0231
Coding: 0223060102002001400040
Shop #: WSC 00156 758 00055
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
VCID: 397998E3B8599B879E-806C
1 Fault Found:
13705478 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 21
Mileage: 165085 km
Date: 2020.05.23
Time: 22:20:42
passive
Part No SW: 5Q0 959 595 B HW: 5Q0 959 595 B
Component: TSG HFS 020 0025
Serial number: 17091403110734
Coding: 000C87204000040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
Serial number: 17091406070733
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
End-------------------------(Elapsed Time: 04:51)--------------------------
you have a few errors in the gateway module that need fixed. Is it code for things you don't have?
Have you wired the button for parking in correctly? It says there's an open circuit. There are 2 wires you need to add. one for switch and other for the light.
Yes i did 2 wires
T20/13 to T/26/14
T20/3 to T26/3
But i did found out there was allready a wire on T26/14 a black wire so i add on the existing cable
Verzonden vanaf mijn iPhone met Tapatalk
But besides that i can activate the park assist
But when i slowly drive by the parking spots i seems could not find a empty space to park
this is the abs sensor provide in the kit i hope its the good one or a wrong one
Anyone has some diagrams?
Or how to resolve ?
Is the abs sensor the right one?
@Philip85
Let me help solve the errors:
1 Fault Found:
Wireing fault: T26c/4 (not 14) goes to T20/13
5 Faults Found:
U1003 00 [008] - -
It can be the wiring is not correct. Only 1 of 3 power wires are switched. Make sure you have the right one.
You have CP on 5f (guess its hacked..) There is no need if hacked, just comlemantary to remove cp.
Cannot be reached
You dont have external navi. Please remove from 19
Cannot be reached
You dont have external audi amp, please remove from 19 (or 5f)
Address 5F:
Dealer tool odis (at dealer) will remove cp (ask hacker of mib2 if cp removal can be performed. There is no need, just comlemantary.
Guess no dab antenna?
1 Fault Found:
13705478 - Databus
No idea, but 6c is easy.
You can pm with new log..
Part number is WHT003864B both is the same part number
My old one were black, new grey, with extention a (same partnr with an extra A. )
If you needed to change ABS byte (26??) to 50 0r F0 to make it work you have the right ones.
Try using the indicator pointing the parking place..It might be a setting in your pla module picking the wrong side of the road. (uk/eu)
R u dutch?
Reactions: Philip85
Hello everyone
Thank you for the reply indeed yes 50 i chsnged to f0 and the car parks like a champ
Very good
