Audi S3 apy Pistons
nevermore1983
Durham
Hi all my friend is rebuilding engine for his girlfriends car its a S3 with the APY engine. we removed the pistons today and the skirts are really worn, so we are trying to find a new set of pistons. what is the best place to buy them from as i am struggling to find any. this car will never go past stage 1 and there on a tight budget so all we want is stranded set. Thanks for any help.
By worn I assume you mean the coating is worn of a bit?
This is normal and does not indicate they are worn beyond useful life..
There are plenty of pistons available but you will be paying around 500 a set.. if paying this much you may as well get the block bored as its pointless spending 500 on a set of pistons to fit worn bores...
Std bore is 81mm... here are some 82mm pistons...
http://badger5.biz/epages/3927bc2c-...a5-d6cca869fcd6/Products/wossnerpistons18t_82
If doing that then its worth doing the rods too...
And if doing all that, it's equally worth getting a TFSI crank and making it a stroker build... slippery slope, weeee!
Probably not for stage 1 lol... ;)
Anyhoo... back at the OP...
In my experience 1.8t pistons don't 'wear'... I have yet to see any on all the engines I have worked on that are unserviceable from 'wear'... pitted from pre-ignition, dented from valves, broken/worn rings, worn gudgeon pins but not worn pistons or skirts as such...
If you have obvious wear then you have bigger issues as the bores are most likely damaged...
You have not mentioned that you have measured the bores for wear or ovality or why you are rebuilding the engine in the first place... engine rebuilds don't normally happen because you feel like it... its usually prompted by another event such as low compression etc... just basing piston replacement on what a piston looks like without taking in other factors such as bore wear seems a little bizarre to me.
'New' OE type pistons are going to be around 100 quid each... its pretty pointless dropping std size pistons into worn bores without checking for bore wear at this point else you could end up spanking 500 quid and still not getting a sound bottom end..
At the very least you need to inspect the bores, measure wear and ovality and if its all in spec then you can get away with new rings and a bore hone...
Do you have some decent pictures of the pistons showing the wear? its normal for the black PTFE coating to 'wear out'...
Please also note that not all 20mm pinned OE pistons are the same... I had worn pins on my AMK pistons so used the pistons from an Ibiza Cupra as I couldn't get hold of separate pins to replace them and the K03 turbo'd 20mm pins are different to the K04 turbo'd ones...
5K
19
12
734
