EGR/THROTTLE BODY REMOVAL 2.0TDI 8P A3 2007
Jamesrg
Audi A3 2.0 TDI 2007 8P
Ipswich
Hi,
i have a rough idle on my 2.0tdi 8P. i want to remove the throttle body and give it a clean to see if this cures it, but while im there i want to clean the EGR also, just want a quick guide if anyones has done this before on what ill need, the EGR and Throttle Body are inline together if im looking at the correct thing? - also on my old Astra when removing the EGR, coolant would come out and empty the car of it, is the A3 the same? will i need to replace the coolant or does none come out?
Any help would be appreciated,
Cheers guys
Just unbolt it and clean with engine degreaser and a small wire brush. They can take awhile to clean. No Coolant loss :)
Sent from my D5803 using Tapatalk
Reactions: Jamesrg
O and don't drop anything down your boost pipe!! Cover with a rag or tissue :)
Cheers kaos,
just didnt want to whip it off and have no coolant on hand in case haha! another ++ compared to the old machine!
thats for the EGR and throttle body? un bolt both and still no coolant loss? haha
And does it 're align itself or need to be done by a computer:?
They kind of come off together. One long bolt goes through both then the others join them. No Coolant anywhere near it. Only the EGR cooler near turbo has Coolant in it not the EGR itself. And no just stick it back on no messing :)
O before I'am shot down for wrong info... Is your EGR vacuum or electronic? Mine is 06/07 and vacuum. I know later swapped to electronic but not sure when. Either way I'am. Sure all is same
electronic i assume as theres a plug that goes into it? how would i check for defo?
