Hi I don't recommend to buy grooved .. I had it and it isn't good when you braking from fast speed ... It makes drill or whirl sound.. Just get drilled onlyHello everyone! I'm looking for pictures of drilled or grooved 312mm front brake discs, preferably on a car with 19 inch wheels. I'd appreciate if anyone could share it.
I had them on a3 2011 they didn't squeak MTEC is entry quality but grooved discs always has added sound as air goes through grooves so makes vibrating soundThanks Peter. I never heard of or paid attention to this MTEC brand. I was looking at Brembo or Zimmermann just because I have heard of those brands from before. Is MTEC any good? Are they squeal when you braking? Do drilled discs make any/more sound in comparison to the ordinary discs?
I bump my original question about a picture of a car with 19" wheels and 312mm drilled discs. Do people even buy drilled brake discs for non-S cars (meaning for the cars with brake rotors smaller than 340mm)? I was just thinking if smallish drilled discs would look silly. Or not?
Absolutely NOT any performance gain.. this is just for pure look!I was going to buy normal coated brembos when I saw drilled and grooved discs and thought what if I fitted them instead. I don't believe I'll get any performance gain of the drilled/grooved discs as my car is DD and honestly I don't need it. It's just for the looks sake. But if I fitted the drilled/grooved discs, I would need to replace the rear ones to match and that would be another expense. Do I even need it? Do people fit drilled rotors to the front and leave plain discs on the rear axle?
I think there is no better or worse because I don't know Otto Zimmermann, (now I know haha googled them) but both are germans companies and they do this stuff BEST So whichever will work out cheaper get thoseAgree on drilled vs grooved. Do you think the drilled rotors will look good in this size? What wheel size do you have on your car? Are you going to replace the rears too?
Are the drilled brembos better than mtecs or zimmermanns? There is a nice price on zimmermanns on ebay here: https://www.ebay.de/itm/202582403855
It is not gas but dust. Each time we break by friction and heated pads wears so all dust falls onto the whole wheel even ''modern'' or you wanted to say more quality ones? those wears too. Old pads been made from asbestos they been banned as asbestos is bad for us and environment ..We use ordinary ones metallic ones.. Metallic brake pads are comprised of anywhere between 30% and 70% metals including copper, iron, steel, or other composite alloys. These various metals are combined with graphite lubricant as well as other fillers to complete the brake pad.Drilled discs originated when brake pad materials gassed off a lot under heavy use, and the gas buildup meant the pad pressure was reduced. Modern pad materials don't do this. There is less metal, which actually means poorer heat dispersal. You might get slightly quicker initial bite in extremely wet conditions, but then again you're not racing. The drilling (and of course grooves) will scrape away at your pads, getting through them quicker. Drilled pads used hard will crack around the drilling. Frankly, if plain ventilated discs are good enough for endurance racers, they're good enough for the road. On a normal road car, even driven quite hard, plain discs are all you need to stop safely. So, it's basically cosmetic.
uuuh what a nasty cracks on those discs .. makes me uncomfortable.. brrr
@Peter82 , you wrote you had a set of plain 312mm brembos. Do you have a possibility to weigh one of them? The zimmermanns I linked to weigh 8.3 kg. I'd like to choose the lightest option.
What if slightly different material or design was used?The lightest will be the thinnest, and therefore the least durable and most likely to overheat.
I was ready to send you link but had to go somewhere and I forgot after...@Peter82 , you wrote you had a set of plain 312mm brembos. Do you have a possibility to weigh one of them? The zimmermanns I linked to weigh 8.3 kg. I'd like to choose the lightest option.
That 1.6 is his old car ... His main is 2019 I assume it is 1.8L or 2.0 he wants to put on...Bit of a strange concern when you're rocking heavy 19" wheels on a 1.6 tdi , those wheels are robbing you of alot of dynamics because of increased unsprung mass .
The extra weight - unsprung mass disadvantage of say going bigger brakes is offset by the brakes greater leverage forces bringing a huge difference to braking .
... this is just for pure look!
Thanks for the link. The 312mm brembos weigh 8.6 kg. I've ordered a set of drilled zimmermanns from my link above as a lighter (8.3 kg) and cheaper option.I was ready to send you link but had to go somewhere and I forgot after...
Here is page you can check everything ; brembo discs and brembo pads looks like now they added even calipers wow designed for A3.. tepmtiiing
I got kit as brembo told me to do so .. I picked discs and pads mine car I must say pads are perfect quality as I drive fast and brake agressively and when I was doing callipers removed pads they looked like new haha still plenty of pads .. hah
I picked on their website A3 2.0 tdi quattro which I have (135 KW / 184 CV) 05/13 - 07/18 year
It is all the same anyway don't know what is yours car if 1.5 liter or 1.8 or 2.0L but only becuse they asking to choose... what liter you have..
U can configure page yourself and there should be info about all parts ..
https://www.bremboparts.com/europe/...sportback-8va-8vf-2-0-tdi-quattro/000055598-1
What would you say about the 288mm front rotors like audi fits on cars with smaller engines? That's why I'm upgrading to the 312. My 288mm discs look lost, I agree. I hope the 312mm ones will improve the look a little. There's a thread on the MK7 forum on upgrading brake discs from 288mm to 312mm. The only thing you need to change is the calliper carrier and the disc. The calliper itself is the same for the 288 and 312 version. I saw pictures. It looks better. Those who upgraded reported smother braking which I'm looking forward too.312 look lost with 19" considering 312 can fit under 16" .
Is there a simple way to upgrade with larger caliper carriers etc and gain better braking ?
You could've go for whole kit brembo; discs, pads and calipers S3 discs 345mm fronts and 310mm rearsWhat would you say about the 288mm front rotors like audi fits on cars with smaller engines? That's why I'm upgrading to the 312. My 288mm discs look lost, I agree. I hope the 312mm ones will improve the look a little. There's a thread on the MK7 forum on upgrading brake discs from 288mm to 312mm. The only thing you need to change is the calliper carrier and the disc. The calliper itself is the same for the 288 and 312 version. I saw pictures. It looks better. Those who upgraded reported smother braking which I'm looking forward too.
But there is a disadvantage too. The bigger brakes are heavier. And I noticed that underpowered cars like mine is sensitive to increasing the unsprung weight. Here is my latest example. I changed my old S3 replica wheels to the RS6 reps. I had smooth ride on my old wheels. The smoothness gone after the change. It feels like my stock shocks are unable to smooth the ride and I feel small shakes all the time I hit a road crack etc. The difference between the wheels is 900g of added unsprung weight. So after I upgrade to bigger brakes, I'm going to get lighter wheels too.
I've been thinking of this in a while and abandoned the idea. If 288 > 312 conversion adds approx. 1 kg of unsprung mass to each corner, think what would 340mm rotors and larger callipers do? And don't forget the price of the S3 or BBK setup.You could've go for whole kit brembo; discs, pads and calipers S3 discs 345mm fronts and 310mm rears
Yes I might get some brembo calipers or rather used S3 ones and fit 345mm front and 310mm rear312 look lost with 19" considering 312 can fit under 16" .
Don't forget about an added unsprung mass and how it will affect your car dynamics.Yes I might get some brembo calipers or rather used S3 ones and fit 345mm front and 310mm rear
Oooh don't worry that one kilo not gonna be noticed at all there is always slack or reserve .. u didn't add any unwanted kilos at all ..Don't forget about an added unsprung mass and how it will affect your car dynamics.
My old oem 288mm discs weight 7.3 kg. My new 312mm zimmermanns weight 8.3 kg. That means I added 1 kg of unwanted unsprung mass. Can't even imagine how much would I add if I upgraded to 345mm discs (and I don't even know how heavy the S3 callipers are).
Oh are you sure it is not just imagination??I don't want to argue about it, but as I mentioned earlier, I experienced a noticeable comfort drop after changing to only 0.9 kg heavier wheels. And now I added 1 kg more. I'm seriously considering new (lighter) wheels.
I have literally same car as you and standard discs are 312mm really don't understand, how come u had fitted 288mm ones .. hmm
where did u buy the car from?
S3 calipers aren't that huge. The difference from A3 are minimal only 3cm bigger
Imagine RS that is something else 4 piston and discs cost like £500 + pair
Blue caliper is mine
Yeah I meant like on side so x2 So all 8 are pressing from both sides then ?Gosh they are crazy expensive grand and even used brand new can be 2k or 3kThe Rs 8V Calipers in your photo are 8 pot. The RS calipers on the 8P as you rightly state are 4 pot.
noo no haha pointless for A3 .. mine are just fine for nowYes correct... The price per caliper is £579+ vat each if you’re interested.?
