OliS3
Yes it is. I haven't fitted mine to my 2019 yet but did 25k on my last car.
Interesting, mine does a very hard shift from 1st to 2nd after its been started. Are the dealers aware of this then?Nice to hear you fit one to your new car as well!
Then we can get some activity on this thread again.
I’ll get mine fitted in a couple of weeks I just need to get the software updated on the gearbox first to fix the problem with the gear change after you’ve just started the car and accelerate hard in sport mode where it gets confused and jumps out of gear.
Is there any particular reason that the boost increase is less at lower rpms in the supplied maps? Is this for mechanical sympathy of the auto box? is it necessary on a manual with an uprated clutch?I can understand reducing it at the very top end since that's when fuel demands are at their greatest but at lower rpms I would have thought the fuel system and turbo should cope quite happily.
Already got an uprated sachs clutch since the stock junk failed last year.
Nice figures btw. My mods will be the same as yours except Ive also got a revo uprated intercooler. Somewhere around 375, 380 would certainly be very nice to have.
What an awesome post!! I think once my tax returns in the JB4 and r600 intake is deffo on the cards!!!!
George is the man to go to but feel free to ask when the time comes. I've read the entire thread on Vwvortex and it's certain that you have to be some kind of nerd to understand the graphs and the relation between the different settings
Don't know if @OliS3 has gotten around to fit one to his MY19 S3? He also got some knowledge about the JB4.
EDIT:
1.000 like anniversary - woohoo!
EDIT:
Good figures, you running map 6?I can vouch for the JB4. Got only JB4 and Intake and car vboxes 3.9s (sometimes 3.8) 0 to 100km/h. Car is S3 FL.
400m @ 12s flat
No idea on power though.
400m @ 12s flat
Hi all. Map1 only.
I run JB4, I have a panel filter, decat and GFB DV.
Did a couple of Dragy runs, boot full of work stuff, 1/2 tank of fuel and two kids seats :
3.66 - 0-60
11.55 - 1/4mile
I run map 6 :
Boost safety 27 and fuel open loop 50.
1500 15
2000 16
2500 18
3000 21
3500 23
4000 24
4500 23
5000 21
5500 20
6000 18
6500 17
7000 16
3500 23
4000 24
4500 23
Damn ... is that like about 7-8psi over stock at 4krpm? must feel incredibly torquey in that part of the rev range!!!
Agree! It's crazy in 1st to 3rd since the ecu can't correct the boost as it normally would in the first three gears because it's absolute values.
Must be pulling like a train![]()
Just a log from my JB4.
Pull from 3rd gear into 5th
Are you running lean in 3rd gear or am I reading the log wrong?
I am getting P0000 No Description Found when reading the codes, and it won't go away when I clear them? Any ideas what or why??
Hi guys
I was trying to solve a "problem" with some throttle closure at high rpm together with George the other day. Then it hit me, maybe I should try to do a map 0 map just to see if it's still there and it sure was.
So, could some of you guys with FL 7-speed gearbox see if you also have throttle closure at high rpms? Normally this would indicate some overboost but I just think (and hope) it's the nature of the S3 with the torque vectoring.
And just FYI: FL cars with the new 7-speed gearbox is not good at boost at high rpms. You should taper it down to 0psi from 6.000rpm to 7.000rpm (George told me this). Right now I'm running the below map 6 and when I push it I manually shift at 6.500rpm since nothing happens after this anyway and I prevent the throttle closure.
You can see what I'm talking about below:
Map 0 - 3rd gear (stock)
Map 1 - 3rd gear
Map 6 - 3rd gear (Little different settings than above)
