Jonathan Carling
- Joined
- Jan 27, 2016
- Messages
- 5
- Reaction score
- 2
- Points
- 3
The diesel particulate filter light appeared on my dashboard a week ago, been in "limp mode" ever since even after blasting down a dual-carriage way for 30 minutes (as per recommendations) but no luck. Took it to my mate's garage where they've tried flushing it and a re-gen but it's still failing to do so.
I've read mixed views on whether or not to replace the DPF and re-gen or to instead completely remove it and get the ECU remapped - wondering if any has opinion/recommendations?
If I replace it, is it likely to happen again soon (it sounds like a common fault)?
If I remove it, will it still pass an MOT? Will it harm any other part in the long run?
Thanks in advance!
Thanks in advance!
you are with the tester guy .
