Something about it here https://www.audi.co.uk/owners-area/...es-and-service-plans/roadside-assistance.html
Cheers for that. Puts mind at ease![]()
If I get that from my S4 then it will be an improvement on the 400 I get off my oil burner 2015 Q5!!Range update. After the latest fill up (BP Ultimate) it showed 430 miles
It creeps up a little bit each time.
Hmm I get 300 miles (actual) if I'm lucky from my current S4, and that's on the good stuff!
Seriously? That's 100 miles more than my last one. Haha. But today was my first work run (to) and I achieved a healthy 34mpg. Very impressed. So the computer registers the short memory stats and then applies that at each subsequent fill up?
but there again we wouldn't be buying 'S' cars if we were overly concerned with economy
Well, with a 58 litre tank, that's an overall average of 33mpg. Since my commute to work is a steady 50mph on A roads (even though I really wish I could do it at 90mph) that does pump the range up a bit. I do then look at this as credit to spend being a hooligan on occasion![]()
Indeed. I had a very uneconomical blast down some B-Roads yesterday. Brilliant fun, it doesn't half shift when encouraged to do so![]()
The massage seat will take a bit of getting use to, I must admit, the +3 kneed setting freaked me out a little on my test drive!
). @Thundercliffe81 - Was that a B8.5 S4 ?B8.5 I got 430 on my last year of fill ups and a steady 385 actual. Really surprised me.
Haha! Same. First time I tried +3 it made me jump. But it's died down a bit since. I do like a rough massage though (different forum).
Having had, unfortunately, direct experience it is pretty good...Perfect. Thank you. Going to cancel mine today then. That's quite a comprehensive cover actually to my surprise.
Hmmmm.
So, car still sounding epic.
Few issues I'm noticing.
1. Steering wheel special button not working intermittently. Have to go to drive select car options to reassign.
2. Start up, foot on brake, disengage handbrake, select drive...when I lift off the brake pedal, the car jolts forward quite violently. In a tight space, this could be an issue. Only doing it past week I've noticed. Never happened on B8.5. Thoughts?
Hmmmm.
3. Grip. Could be the tyres (probably the tyres). Couple of times, chronic understeer has occurred. Nothing to suggest it's a characteristic of the car as, I've caned it on some very demanding roads and the sports diff worked great.
Now, it's been in the wet, I admit. On a roundabout on way to work. The B8.5 catapulted me around this thing. But past two days, with less throttle I might add, it's chucked my alarmingly close to the curb. Had to countersteer. And no...I'm not driving like a lout before anybody suggests.![]()
Totally agree sound is awesome. My stereo is now almost redundant.
Yes I've had this happen once, don't know why but it didn't reoccur once I'd used the drive select button on the dash. And hasn't happened again since.
Yes this happens to me setting off in a morning. I'm presuming it's due to the higher engine idle when cold start. In my driveway it's been a bit unnerving a couple of times as I'd hit a fence if I haven't got my eye on the ball.
Driving like a lout, now I'd never suggest that
I'm with you on the tyres, I'll not be putting more hankook's on. They have less grip than the contis I previously had on my s3 particularly on greasy roads. They seem good in the dry though.
I think it'll be a set of michelin's or goodyear's when it's time for a change.
Greasy is the word I should have used actually for the roads. Not wet. Pilot sports maxx (are they?)were very good last time. Spot on there @Brasso.Greasy is the word I should have used actually for the roads. Not wet. Pilot sports maxx (are they?)were very good last time.
High idle, of course. This is during the day though too. Not just cold start. But, I think I'm going to leave it an extra 15-20 secs and see what happens. Very good point.
So, when the steering wheel button fails, just go to dash buttons instead and that rectifies it? The steering wheel button resumes function?
On 2, is there the same issue if you don't use the handbrake at all - i.e. Just put it in Park.? Sure, there is a bit of potential movement, but I wonder if that is what is wound up in the handbrake when you start, and because you've only released the foot brake after you've released the handbrake is causing the jolt? It will be interesting to see if I see this as I have essentially the same transmission in by current BMW 5 series and our LR discovery and we never use the handbrake in either.
Hmmmm.
So, car still sounding epic. B&O has bedded in now too.
Anyway, just some observations. It is a very very different car from the B8.5 S4.
I've not driven the car much, back at work, but the wife has commented on the same thing, I thought it was just her not being used to a powerful car. I'll have a play when I get home and see if it's the same!
Regarding the handbrake and jolt?
I know it's still early days, but this is slightly worrying as I had high hopes for the Hankooks!
Maybe the lack of grip is down to the 10mm less width than the B8.5 tyres lol
I've also had this (mine's not an S4). I found I had to hold down the special button, which brings up the assignment menu. I then had to re-assign it to something else, and then back to drive select.
Do you mean the parts request or parts under classified?
I though parts request was for OEM parts.
Agree, the carbon mirrors look good
. Projex UK seem to be somewhere that would but I'm not finding anything. Update.
Handbrake jolt appears to have gone. Let the idle settle today seemed to work so I'll keep an eye on it. Cheers for your suggestions lads.
